Question about Onkyo DV-SP502 DVD Player
I OWN AN ONKYO DVD- DV SP 502. I AM HAVING PROBLEM WITH THE PICK UP, AND THE SERVICE CENTRE TELLS ME TO REPLACE THE PICK UP ASSY,( 03 SD Pickup Assy-S part no.OXX8005). I HAVR TRIED CLEANING THE LENS BY THE DISC CLEANING CD, BUT WITHOUT SUCCESS. SOME ONE SAY I SHOULD CLEAN THE LENS BY A COTTON SWAB DIPPED IN ALCOHOL, THE PRICE OF THE REPLACEMENT PICK UP IS PROHIBITIVELY PRICED BY ONKYO, HENCE THIS QUERY
  • 1,591 Answers
The someone that told you to try cleaning the lens with a cotton swab (q-tip) was right.
if that doesn't work, check all the cables that go to or are in the pickup assembly.
If all that seems OK, then you very well may need to replace the assembly.
Posted on Mar 27, 2011
  • 1 more comment
  • Todd Hill
    Todd Hill Mar 27, 2011
    mpeg decoder ic
  • Norman Skinner
    Norman Skinner Mar 27, 2011
    I used to do WARRANTY repair for Onkyo, and I replaced 50X more pickup assemblies than mpeg decoders (thank god because replacing the decoder chip itself was a pain with hand soldering tools, as we didn't replace boards unless it was absolutely necessary)
  • Norman Skinner
    And if you do need the pickup assembly, I could probably direct you to an OEM replacement from that same place I used to work. That's right, Onkyo doesn't do their own warranty repairs, it's done by a third party company. The one I worked for is in Toronto.
I NEED UNLOCKED REGION ONKYO DV-SP 403E
Isn't playback automatic? Did you check the user manual page 47?
It explains how to change TV system from Auto to NTSC to Pal, but
the manufacturer recommends leaving the player on the default setting because changing the region may restrict the kinds of discs you may be able to watch.
Jun 10, 2014 | Onkyo DV-SP406S DVD Player
DISC ERROR
I'am afraid you have done everything possible, the laser pickup assembly will need to be replaced, not cost effective to repair cheaper to replace.
Apr 22, 2012 | Onkyo DV-CP500 Multi-disc DVD Player
Hi, so i have the desay dvd player, and im having trouble changing the battery for the remote. the back of the remote says its 04A05 CAT.NO. 16-3901. dunno if thats helpful or not, anyway, i'd really...
If you turn the remote over there is a tab at the top push that towards the bottom of the remote and pull up. Once you have the battery cover off replace batteries with two AAA batteries. Click below for a copy of the manual. The battery replacement is on page 9 of 40 in the adobe document.
Onkyo DV-SP301 Manual
Mar 02, 2011 | Onkyo DV-SP301 DVD Player
Is a electronic cuicuit diagram available for a onkyo dv-sp302 dvd player
ftp://wintex.kiev.ua/%D1%81%D0%B5%D1%80%D0%B2%D0%B8%D1%81%20%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B/Onkyo/DV-SP302DVDplayer.pdf
Here is a link to the pdf file of the service manual which has circuit diagrams. You will need Adobe Reader to open the file (can download for free from adobe if you don't have it already)
Jan 08, 2011 | Onkyo DV-SP302 DVD Player
Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Jun 11, 2009 | Onkyo DV-SP404 DVD Player
My onkyo dv-cp704 powers on but frrezes after
HI...
A problem like that will need tech service.
Check the onkyo consumer site for service people
Dec 05, 2008 | Onkyo DV-CP704 DVD Player
Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Nov 28, 2008 | Onkyo DV-SP301 DVD Player
Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Jan 20, 2008 | Onkyo DV-SP800 DVD Player
Onkyo DV-SP502 DVD Player Logo
187 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
