Question about KitchenAid Microwave Ovens
I have a kitchenaid microwave over oven. It was built in 2004. I do not now model. The open pull is on top of microwave. The door when opened drops to 90 degrees. The latch/spring in door is disconnected. How do I repair? Thanks Larry Walker
  • walkerapprai Mar 27, 2011
    Model #KEMC308KSS01
    Thanks
    Guru:
  • 262 Answers
To be able to effectively help you I will need the model number.
See my tips and how to's for your answer
Please consider giving us a four thumbs up for our rating!
Using FixYa and this procedure has saved you a minimum of $125.00!
kdrake84
Rank: Guru
Rating: 95%, 96 vote
Click on the link below.....
How to find appliance model numbers When trying to troubleshoot or purchasing parts for your appliance the model number is the key to do
Posted on Mar 27, 2011
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
Jan 25, 2015 | KitchenAid Microwave Ovens
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Kitchenaid microwave model KCMS1555RSS-2 door stuck, does not open
Hi Chan Sing,
If your microwave oven is brand new and under warranty then please take it to the place where you bought it from to claim for warranty.
If it over warranty then try this;
First off the power and unplug the microwave oven, open the screws off the cover and slightly lift and pull out the cover from the microwave oven. If you are not a technician then be care full what you are doing.
After you have removed the cover then you will see that at the place you posh the door eject button, behind it there is the mechanism that opens the door when you push the button from outside.
Now you have to analyse the simple mechanism if you are a non technical person, in here you will have to lift a small plastic up which we can call the lever. this is made up of plastic and it should be white in colour.
If you have any problem please let me know.
Regards
Ashwin
Built in microwave light bulb for kitchenaid
Need model number. If this is one of those built-in wall ovens with microwave on top (with the door that drops down), it is definately NOT something the average customer can do himself. It's a 45-minute job for an experienced technician!
Oct 18, 2014 | KitchenAid Microwave Ovens
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
Microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid Microwave Ovens
The door press opener button of my kitchenaid
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, usually only the control panel needs to be removed.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
I'd recommend that your bookmark this link to your favorites.
Nov 27, 2009 | KitchenAid KCMS185J Microwave Oven
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
