Question about Maytag MAH6700AWW Neptune Front-Load Washer
I am looking for a wiring diagram for a MAH6700AWW maytag washer. I have NO lights on the front and the door is locked even when I unplug it. Anyone have any ideas? I went to Maytags web site with no luck. Thanks DJ
  • Maytag Master
  • 3,361 Answers
Www.appliancedigest.com has your manual.
You will have to register for free to download the manual.
Posted on Mar 27, 2011
Unlocking a may tag door washer
Fuse open ... must meter all the fuses in the back. Use an ohm meter.
Jun 02, 2016 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
I have front loading Maytag Neptune. Can't get door to unlock. Cycle started, but door wasn't closed properly, signaled "do" and when I tried to open door, it was locked and won't unlock. Have tried...
After getting no response from FixYa, because it told me that my session had ended, and I hadn't even started, I called a local repairman! I had better not be charged for your service, as you site is faulty and gave me no assistance or info, just seemingly took my money.
Jun 29, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Cant get the door open...
In the dispenser there should be a emergency pull strap to release the door in case of power failure.Try unplugging and plugging back in first.
Eric
Jun 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My maytag front louder door won't lock or even stay shut?
it sounds like you have broken the switch which keeps the door latched when not in use as well as locks when the washer is started. These latches often fail when someone forces the door open to add more clothes without pushing the pause button AND waiting until the "locked" light goes off. Older children and teens and yes, uninformed men, are apt to do this. You will need a repair person.
Jun 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer door stuck locked. Will not open.
access to pump through the back of machine if water in the machine it locks up after 3 attempts to pump out clear the pump by taking the hoses off and yes you will need lots of towels hopefully if you clear the pump reassemble thats the repair done door opens after water pumps out always unplug the machine first
Jun 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Aug 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
365 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
