Question about Canon LASER SHOT LBP-3000 Printer
How to redirect lpt print to canon lbp-3000 printer
I am having dos (foxpro) programme that prints to lpt port. I am having canon lpb-3000 printer. I want to redirect the print for dos programme to usb connected canon lbp-3000 printer.
plz give the soultion.
Gopal joshi
[email protected]
  • Anonymous Mar 13, 2014
    double side printing on lbp 3000
  • Anonymous Mar 20, 2014
    line problem in canon LBP 3000
The LBP-3000 is a GDI (AKA Windows-only) printer, accordingly with its Specifications, so, there's no way to drive it simply redirecting the DOS data flow.
You may want to have a look at Printfil to enable DOS printing to USB/GDI printers
If you're the original Fox programmer, you may also find this article useful: How to print from Clipper DOS to any Windows printer (well, it was written for Clipper, but Clipper and Fox are pretty similar)
Hope this help.
Regards,
Davide
Posted on Aug 04, 2008
    Scholar:
  • 162 Answers
Here's what you need to do. ON the computer that you want to associate that LPT1 port, you need to know the name of the computer, and the share name of the printer. In this case, I am assuming you have the Canon LBP-3000 physically connected to this system running the FoxPro program.
Step one: Find the computer name. Click on START SETTINGS CONTROL PANEL. Double click SYSTEM. Click on the tab COMPUTER NAME and under FULL COMPUTER NAME, write down the name. Click OK to exit the window.
Step two: Click on START, SETTINGS CONTROL PANEL. Double click PRINTERS AND FAXES. Right click on the Canon LBP-3000 printer and click on SHARE. In the window that opens, click on SHARE THIS PRINTER and take note of the name in SHARE NAME: and write it down. Click on OK to share the printer and exit out of the wizard.
Step three: Click on START, RUN. Type CMD in the box and click OK. in the black window, type NET USE LPT1 \\COhow to redirect lpt print to canon lbp-3000 printe - 43f150c.jpg\SHARE NAME
Follow with RETURN or ENTER and you should be good.
  • Gary Luis
    Gary Luis Aug 04, 2008
    Keep in mind not all USB printers are able to print to DOS or are compatible with DOS. If the above doesn't print to LPT1 but the COMMAND COMPLETED SUCCESSFULLY, then the printer may not be able to handle a DOS request.
SOURCE:
I'M LOOKING FOR CANON LASER SHOT LPB 2900 DRIVER INSTALL. I tried to install sugested driver, but it's not working. Thank you
You preferably use the original driver cd which comes with printer.
Check the USB printer interface cable.
Ones you remove the driver from the system (Add / Remove Programme)
Restart the system, then load the driver.
Print a test print
Apr 28, 2011 | Canon LASER SHOT LBP-2900 Printer
I have given a maual printing option for canon lpb 2900b i got trouble in printing each and every time i have 2 restart printer 2 print one paper.
have given a maual printing option for canon lpb 2900b i got trouble in printing each and every time i have 2 restart printer 2 print one paper. Also printer going automatically paused stage. Please solve this issue
Sep 01, 2010 | Canon LASER SHOT LBP-2900 Printer
I have a printer Canon LASER SHOT LBP 1210 but i can't set up page size Legal thats mean 8.5"x 14.00". Would u pls give me solution how can I get print in the legal size print.
I am Canon LBP 1210 User. canon LBP 1210 laserjet printer not supporting legal size printing. When I give a legal size page printing, there is no response from the printer.Please give a solution.
Aug 22, 2010 | Canon LASER SHOT LBP-3000 Printer
HAVE A DOS BAKERY PROGRAM THAT IS USED DAILY. OUR XEROX PRINTER BIT THE DUST AND MY BOSS HAD ME RESEARCH AND PURCHASE A NEW ONE. PURCHASED A CANON MF6540. ONLY PROBLEM IS, NO ONE TOLD ME IT HAD TO BE A DOS...
There is a workaround that will work for many dos based programs.
It will remove several of the advanced feature from your printers functionality but may solve the problem.
Try this:
Open control panel, switch to classic view if not already in it. Open the Printers folder, then Right-Click on the Canon MF6540, select properties.
Once it opens the instruction may vary slightly for your printer but should roughly be:
1. Select the advanced tab, then click print processor, then select one of the RAW modes on the right and Ok twice to close the windows.
2. Try printing in the DOS program, if it fails, repeat step one and try the next option. If none of the RAW modes work, try the TEXT mode.
If none of these methods work you may need to emulate a LPT Port for the DOS program to Print to, forward it to the Printer and then repeat the above process. DOS programs are notoriously finicky about settings so you will likely have to try several settings to find one that matches.
If your first attempts fail and you need to emulate the LPT port get back to me by adding a comment to this post and I will see if I can find a good emulator to try for you. Or you can buy a router to connect the printer to that already has emulated LPT software such as the Linksys WRT610N. Sharing the printer through such a router creates a virual LPT port on your computer which may work.
If you need more direct help, try clicking my name and clicking Ask Me for paid support. If you can handle the normal speed here in the forums simply reply and we will help you as soon as we're able.
Hope this helps FixYa,
Chris
May 14, 2009 | Canon Office Equipment & Supplies
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos programme not printingin usb printer laserjet cp1515
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
LPB 1210 printing problem
canon lbp1210 laserjat legal size page printing solution
Nov 20, 2008 | Canon LASER SHOT LBP-2900 Printer
Printing Both Sides with LBP5100
my Cannon lpb 5100 colours are out of allignment (black OK) - error is "out of Register colours correction"
NOt sure how to solve this problem - calibration does not work?
Oct 12, 2007 | Canon LBP 1120 Laser Printer
Canon LASER SHOT LBP-3000 Printer Logo
744 people viewed this question
Clive
Clive
old marine
old marine
Ekse
