Question about Hotpoint Aquarius WMA42 Front Load Washer
How do you turn off the child lock as i can't change the programme
    Brigadier General:
  • 6,277 Answers
Press and hold the child lock button for more than 3 seconds should release it ;-0)
Cheers,
John C
Posted on Mar 27, 2011
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
Hi,I have lost the user manual for my samsung front loader washing machine IPX4 model www60j426hs and the lock sign stays on. It is stuck and cant change programme. What can I do?
seems as if the washer is in child lock mode pressing and holding a key related to the child lock for four seconds will unlock the washer and allow you to use the washer again
Feb 26, 2017 | Samsung Washing Machines
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
How to remove child lock on Siemens d12-52
To dectivate child lock press the key with the clock symbol for 5 seconds. The child lock will deactivate.
If it still does not then you may have shifted the programme dial. Rotate the dial through each programme and try deactivating child lock in each programme setting. The child lock will deactivate only in the original setting that it was activated.
May 19, 2012 | Kitchen Appliances - Others
Machine on / off button flashing - unable to start it?
Yes indeed the child lock in on, Try pressing it in and hold for 5 secs to clear, any further problem please let me know...
Nov 24, 2011 | Zanussi Washing Machines
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
The machine (HVF 344) has stuck on the last minute of the programme and is permanently locked. The child lock has also come on. How can this be solved?
The child lock comes on when you press the child lock key for two second. To remove the child lock, press the same key for 4 seconds, this worked for me when I recently faced the issue!
Feb 15, 2010 | Hotpoint Washing Machines
A key has appeared in the electronic window and a zero for the duration of the programme. This happened after completing a wash cycle which was interupted and changed a short time into the wash cycle.
This is a "child lock" notification. It was probably triggered by the interruption.
See your manual to reset the child lock. If you see the child lock button, press and hold it for 3-5 seconds and it should beep to reset.
Nov 03, 2009 | Bosch Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
