Question about Indesit Washing Machines
When i switch washing machine on it fuses all electic items in house
  • 2,510 Answers
What you probably mean is that it kick out the earth leakage in the house. You could either have a neutral wire that has shorted to earth or water has gotten onto your circuitry and is enough to kick out the earth leakage - which it is supposed to do. Try drying out the electrics of the machine with a fan heater or a hair dryer for a while and see if that solves the problem. If not do a check from the neutral wire to earth with an ohm meter and see if you get a reading. If you do, you will have to trace all the wiring looking for the leak. If the drying out solved the problem, you need to look for a water leak.
Posted on Mar 27, 2011
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Washer won't start?
Hello there:please follow the items i have provided and click on the items listed in blue
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Apr 20, 2010 | Kenmore 43142 Front Load Washer
I have no power to my machine. the plug is in and the the fuse box is fine in the house and still the machine wont turn on. i started a load of laundry and it lost power befor it finished.
If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't work until you replace the fuse.
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Is there a fuse or circuit breaker i can reset if 220v was put to my washing machine? i was rewiring the breaker panel and got two circuits reversed, the washing machine circuit and the water heater...
Jan 10, 2010 | Washing Machines
My washing machine model 110.24642300 was washing last night and just stopped after filling half way. what do I need to do
Lid switch
Good luck...
Mar 28, 2009 | Kenmore Washing Machines
Dryer operates but doesn't heat
If the power to the machine is OK then check these items.......
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust air flow has become blocked or restricted. Check the hose in the back of the machine for crushed hose. If OK, the vent pipe may need cleaning... check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Jun 22, 2008 | Dryers
Kenmore top loading washing machine
check the outlet to make sure that power is getting to the unit. This can easily be done by plugging in a lamp or some small appliance. If you have power at the outlet, it is most likely the lid switch.
The switch is inside the washing machine main housing near the door frame. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. Unless you are familiar with working inside the housing I would call a technician.
Mar 09, 2008 | Kenmore 22422 Top Load Washer
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Hotpoint Ultima Extra WMA66
something is shorting out direct, remove plug from power supply and test each item, element / pump / main motor etc for down to earth, replace the affected item
Sep 30, 2007 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
