I want to stop the recording i have programmed whle it is running. toshiba D-R7
    Guru:
  • 276 Answers
To stop a timer recording in progress:
On the front panel of the recorder itself:
Press [STOP].
For later models of Toshiba DVD recorders, also add to the above step:
On the remote control:
1 Press [STOP].
2 Select "Yes" using [up/down arrows], then press
[ENTER\OK].
Posted on Mar 27, 2011
I have a Toshiba DVD/Recorder Player. I have misplaced the English manual, and now am left with only the french version. If someone could send me a link to a site where I could read and print it for free,...
Unfortunately I can't find the DR7-KTC3 on any Toshiba Site. The Canadian Toshiba site does have documentation for the D-R7 DVD recorder. See: http://support.toshiba.ca/support/ceg/manuals and search DVD, DVD Recorder, then find the D-R7 and D-R7KC2 in the drop down menus.
The D-R7KC2 may be a similar model with the same features. The site has a D-R7KC3 but no manual has been uploaded yet.
I hope this helps.
(You may want to try the Toshiba support site for your local area to see if the model, DR7-KTC3, is an area specific label.)
Mar 12, 2011 | Toshiba Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
My Toshiba laptop freezes on using my recording device
Maybe your memory is not enough to run the device. If you memory more is high than 256 MB, please check if you are running too many program that use large memory to run. If the problem persist, it may cause of the device. Maybe it has get damage.
Feb 17, 2009 | Toshiba Satellite A215-S7437 Notebook
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Recording trouble
Hi again,
Lost you twice on the Live Session, must be a glitch somewhere.
R7 doesn't work properly
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Apr 24, 2008 | A4tech R7-10 Mouse
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Insert disk indicator problem
Unit may have defective disk motor or optical pick-up. There is a chance the lens on pick-up may need cleanning. If you can reach it, try gently useing a q-tip in a circular motion on lens
Jan 06, 2008 | Philips FW-R7 CD Shelf System
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
