Question about LG Computers & Internet
Disc drive will not eject - LG Computers & Internet
    Guru:
  • 433 Answers
In fornt there is a small hole use apin and press will eject best regardes
Posted on Mar 27, 2011
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Where is the eject button to open my disc drive?
In some laptops you press and hold the control key and then the disc eject button (its a key on the keyboard).
Sep 20, 2014 | Computers & Internet
How to eject disc
To eject a CD from your disc drive, follow these steps.
1. Go to My Computer.
2. Right-click your disc drive (e.g. DVD RW Drive (D:)
3. Select "Eject."
It should automatically eject your disk. If not, there may be a hardware problem where you might have to contact your manufacturer. Hope this helped.
Dec 04, 2013 | Computers & Internet
Cd stuck in E: drive on my HP TouchSmart 300 PC
You will have to manually eject the disc. take a straightened paper clip and find a little hole near the slot where the disc goes in. Insert the paper clip and it should eject the disc. If there is no hole, you may need to access the disc drive by removing the back panel and/or disc drive faceplate.
Apr 12, 2013 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
The drive will not eject games, and will not read games once removed. The drive just makes a whirling sound and I have to hold the ps3 @ an angle just to eject games. And now the drive won't accept...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the PlayStation not ejecting discs is a bad drive.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This drive should fix any issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PlayStation including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PlayStation going again!
May 27, 2010 | Sony Playstation 3 (PS3) Console
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
