Question about Suspension & Steering for Toyota Yaris
Loud 'clunking' noise at front of car, not necessarily when in gear. Car sounds alomst as something is 'hitting' the ground. Especially going over speed bumps/corners.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 207 Answers
Have your front struts inspected.
Posted on Oct 21, 2013
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Clunking noise from 09 charger front end
That sounds like a loose exhaust pipe or a metal cover plate underneath that has come loose.Check it out.
Apr 15, 2013 | 2008 Dodge Charger
Very very loud clunking noise from front end...
Before you look at that, check the front end. With the front wheels on the ground, wiggle them from side to side with some force and see if there is any freeplay. If there is it is probably one of the ball joints that has worn. This is quite dangerous and needs to be attended to immediately ut the cost of repairs in not high. Whilst you are checking the front end, make sure that all the mountings are tight. Anything loose can make some very interesting sounds. Another thing you can look at is the u/j on th propshaft. If you get under the car and grab the propshaft, and move it from side to side in the direction it would be going if the car was running and you can hear it clunking or there is any freeplay, that could be your problem, but the noise would be coming more from the middle of the car.
Feb 27, 2010 | 1995 Jeep Grand Cherokee
Front end loud noise like an old bed clunk, honda crv 2000
its probably your sway bar end links, I had the same problem, I replaced both sides and the bushings and no more clunk noise
Apr 26, 2009 | Honda CR-V Cars & Trucks
Clunking noise in the front right when coming to a stop
first off the alt. belt is too tight. loosen it. should go away. and if its a clunk in the frount end i would guess it is your struts or bushings or both.
Apr 02, 2009 | 1990 Toyota 4Runner
Acura Integra '92 loud clunking when accelerating
you can check the wheels make sure there on tight and make sure you tie rods and wheel bearings are good
Dec 30, 2008 | 1992 Acura Integra Hatchback
Clunking and grinding noise
My 2003 F150 Supercrew would not engage in 4x4, it ended up being the shifting fork in the front end, cost me $200.
Jul 16, 2008 | 2005 Ford F-150
Transmission making loud clunking noise
sounds like your torque converter.
Nov 23, 2007 | Computers & Internet
Suspension & Steering for Toyota Yaris Logo
210 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
