Question about Refrigerators
The refrigator works however the comressor is not working and the lights are out for the temp controls
    Sergeant:
    Champion:
  • 202 Answers
Hi... you have a bad start relay and run cap
Posted on Mar 27, 2011
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
Pfs22mbw HI I came home and my refrig light is on
I believe that the main control board or the temp display board have gone bad. The fridge will not run without both boards working. I purchase my parts through www.appliancepartspros.com . I am unable to provide any other information as far as narrowing it down further other than replace the temp board first. Maybe another expert will have that information and can add it to my own.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 02, 2017 | GE Profile PFS22MBW French Door...
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
The light in the refriderator has no power getting to it and the temp display has no light showing
You have a Whirlpool refrig and it has a bad control board . This board is located behind the refrig , on the left side at the bottom , inside a plastic housing . This housing is held on by 2 screws at the bottom left . Remove the housing and the control board inside . Replace the board and reinstall the housing . It costs about $ 80.00 . When you go to get the part , take the complete model number with you so you get the correct board . This board controls the light for the refrig AND the lights for the control knobs PLUS other parts which work ok relating to the cooling .
Sep 23, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
Inside lights not working on frig side, working on freezer side, changed all 3 bulubs
You have a bad control board , located behind the refrig , mounted to the bottom left corner , inside the white plastic box . Also , the temp adjustment light , should be out . This board , is held onto the refrig , by those 2 , 1/4 " screws . It is easily replaceable , and costs about $80.00 .
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
642s Temp Setting Does Not Work
Possibly, but check your condensor before calling for service.
May 28, 2009 | Sub-Zero 642
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
