Question about Frigidaire Dryers
Tub makes a whistling noiseconstantly as tub spins.
  • 2,510 Answers
Something is rubbing between the inner and outer drum or the belt has a slight slip.
Posted on Mar 27, 2011
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 14, 2012 | Whirlpool Washing Machines
At the end of the cycle prior to spinning the washer sometimes doesn,t start to spin, it just makes sounds like it,s trying to spin but won,t catch. If I open and close the lid it begins it,s proper cycle....
The timer is not allowing a cycle stop for the neutral pack to drop. Replace the timer and you should be in good shape. The whistling sound is likely something in the pump.
Kelly
Mar 21, 2011 | Whirlpool Washing Machines
2000 LINCOLN TOWNCAR SIGNATURE SERIES LIMITED EDITION WHEN I START MY CAR IN THE MORNING I HEAR A LOUD WHISTLE- ING NOISE FOR 15 MINUTES UNTIL THE ENGINE WARMS UP AND WHISTLE NOISE STOPS. I REPLACED...
well it may help if you open the hood, then start the car and see if that helps you locate the item which is whistling. many cars have a power steering pump which likes to whistle until it gets warm. generally this is less than 5 minutes, and that is more like a screeching sound. something is either blowing out or sucking in through a small orifice to make the whistle, you need to physically locate the source of the sound. many bearings are in there spinning and any of them can be doing a cold screech.
myself I have been know to use a BFS, which is a big long screwdriver, i touch the pointy end to each of the spinning components and put the handle end to an ear. yes this process is not suggested for people with long hair or just no damn sense. but as i move the pointy end from component to component i know immediately when i touch it to the screechy one.
Dec 12, 2010 | 2000 Lincoln Town Car
95 jetta whistling/screaming sound
Plural husbands? Check each wheel by jacking up that corner of the car and spin each wheel by hand. If one of more of the wheels makes this sound, there may be an incorrectly installed pad in the brake assembly which could be dragging on the rotor. Make sure that each caliper will retract properly. Hope this helps!
Apr 03, 2010 | 1995 Volkswagen Jetta
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
Whistleing sound on golf gt tdi
It's probably the turbo you're hearing. They spin very fast and make a noise like that. Ever hear an 18-wheeler go by you and accelerate and they make that high-pitched whistle? That's the turbo spooling up. Now, if it sounds like a dentist's drill, that's usually a sign that the turbo is failing, but I'd bet that since your car is under four years old, as long as you've kept up on the maintenance, it's the normal turbo spool.
Aug 16, 2008 | 2005 Volkswagen Golf
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Jul 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Dryers Logo
170 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
