Question about RCA Audio Players & Recorders
I have a RCA rtb 1013 that will not connect to netflix through my router. If I connect directly to me comcast modem the connection goes through but if use the router I get 0.0.0. established and then a note that says www.rcara.com not established. Any ideas
    Brigadier General:
  • 5,158 Answers
You need to set up port forwarding on your router for netflix
Single Port Forwarding Application External
Port Internal
Port Protocol IP Address Enable Both 192.168.1.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
there are so many different routers that i will supply you with the site to go to. locate your router from the list and it will explain how to perform this. here is the link to the site
Posted on Mar 27, 2011
I bought this modem to replace the one I rent from Comcast, and want to connect it to my wireless router. The "Quick Guide" gives directions, but only refers to PC installation, and I have a...
first you need to make sure that the new modem is provisioned (added to your account from comcast). you can do this by connecting your router to the coax cable and plugging it in (like the old modem was) then call comcast and ask them to provision the new modem (they will want you to return the old modem a local office to avoid rental fees on it). once the modem is provisioned.
1. unplug the power to the modem and router2. connect the router and modem the way you had it with your old modem (Ethernet/cat5 connects from port on modem to interent/WAN port on router)3. pug both router and modem back in
all should work now as long as there are no funky (meaning non-default) settings on your router. so, long answer to say, "no, there should be no special settings that are different for your mac"
Oct 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I am having trouble connecting my RCA dcm425 with a dynex 10base-t ethernet hub to two devices at once. Comcast said I should be able to connect two devices at once but I can only connect one at a time. ...
The RCA DCM425 is a cable modem. You need an Ethernet router to connect two devices to the wide area network provided by the modem. A router assigns I.P. (internet protocol) addresses. Your Dynex Ethernet hub is a switch which will enable you to share files between computers. It doesn't support directing traffic to and from the internet.
I wish that I had better news for you. You can get a router from many sources.
Feb 19, 2018 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My new rca blue-ray dvd player model RTB 1013 will not receive Netflix instant streaming. when I click netflix it says testing connection then says connection to 0.0.0.0 successfully established. then it...
I Bought a RTB1013 300W Blu-ray Home Theater and I noticed under network setting the was a wireless option but it will not let me pick it. What is up with that and how can I make it work?
Dec 21, 2010 | RCA Audio Players & Recorders
I have a Zonet Router that I am hooking up to Comcast DSL internet. i show that i am connected but i can not get online. i duplicated the MAC address i just dont know what else can be wrong. is there a...
The first thing is that Comcast is Not a DSL connection it is Cable connection. Now first make sure that your computer will be able to go on line when connected directly to the modem. Connect your main computer directly to the comcast modem and check if that goes on line. If not then you will need to contact Comcast and get main computer on line. If it is online then reset your router for 30 seconds. release the reset and wait for 1 minute. Now connect the main computer to the router and comcast modem to the router. open the set up page and Clone the MAC address of the " Main " computer.
power cycle the modem and the router. See if it works.
Click here for more information about router and networking
Apr 19, 2010 | Zonet ZSR1104WE Wireless Router
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Re-Connectivity to Comcast Modem
All you need to do is "MAC ADDRESS CLONING". Access the router's setup page and look for MAC Clone settings. Enable that and clone the mac address of your main PC. After that, perform a power cycle. Turn off the router then the modem. Wait for 30 seconds then power on the modem first, wait for all the lights to go solid then power on the router. That should do it.
Apr 15, 2009 | NetGear RangeMax WPN824 Router
Belkin router problems with RCA modem
Do a powercycle. Make sure to completely turn off the modem, router, after 30 seconds, turn on the modem first then the router.
If that will still not work, perhaps there is a need to update the software of your router.
Aug 24, 2008 | Belkin (F5D7230-4) Router (587009)
506 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
