Flashes up protection on unit constantly - Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 27, 2011
My radio won't do anything, and it constantly flashes protect on the screen. What does that mean?
It means you either have a short in your speakers or speaker wires, a bad speaker or the output IC may be bad.
Apr 27, 2011 | Kenwood Car Audio & Video
Red light flashes - will not work - could it be dust in the amp?
hi,
its not because of dust. AZUR 640A offers loudspeaker protection if the output of the amplifier goes to a high constant voltage (DC) because of some internal fault. This is a rare fault although detecting it could just save those expensive loudspeakers.
Due to the necessary sensitivity of the DC protection circuit, hard clipping of the amplifier may cause DC protection to be triggered. If this fault occurs switch the unit off, power up again and check
operation with a reduced volume level. If the DC fault occurs again contact your dealer for service.
ok
Dec 29, 2010 | Cambridge Audio Azur 640A Amplifier
Red light, turn on, goes green, flashes yellow then flashes green
connection problems or power surge connect to surge protecter
May 01, 2010 | Sony Playstation 3 (PS3) Console
Warning light on my 1990 Chevy Suburban ''Brake'' flashes 1 long and then 12 short flashes (constantly) What does it mean and how do I fix it?
The control unit for the ABS is bad. The only fix is to replace it. Google it and I'll bet you can find rebuilt units cheap.
Dec 30, 2009 | 1990 Chevrolet Suburban
Kenwood excelon cd player flashes protect
check your wiring the unit is doing the right thing by by shutting down or your check you skpr terminal
Jun 25, 2009 | Car Audio & Video
Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Jun 03, 2009 | Sharp LC-26D43U Television
Flashes protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 06, 2009 | Sony STR-DE895 Receiver
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Jan 26, 2008 | JVC HX-D7 Shelf System
13 people viewed this question
 Grubhead
Grubhead
