Question about AEG Favorit 50500 Built-in Dishwasher
Aeg favourite 50500 machine will not complete cycle but pump still runs . i have taken side panel off and dried water out of bottom of machine how do i get to leak???????? Ihave tried tipping machine through 45% but this is only a temporary fix.
SOURCE: aeg favourit- water not heating up
Viva la bulgaria. AEG 40850 working again !!! Thank you very much. I went directly to the relay, because my dishwasher didn't dry the dishes as well and voila, some 500+ EUR is saved for the moment. Thanx a lot bulgaria.
Posted on May 30, 2008
  • 1462 Answers
SOURCE: Remove bottom front panel AEG 6081
before you take the pump out, if drain hose goes into a spigot on the sink trap, take drain hose off and check hose and spigot are not blocked. this is very common.
can't remember anything special about the screws - used to be philips head but may have changed to multi-spline.the top ones are indeed obscured by the door panel but you can normally get to them with a stubby screwdriver or take the outer door panel off - just a few screws
Posted on Sep 06, 2008
SOURCE: AEG Favourit 446
Our AEG dishie also tripped the light regularly. Turned out there was a water leak by the motors and the cut off device wasn't working and when the water filled up too much it tripped. Move the dishie and if water 'sloshes' out the back, then you know the problem, or if not, take the side panels off so you can see underneath, if there is water at the bottom of the machine. Hope you find the problem.
Posted on Oct 28, 2008
joe_lishman
  • 192 Answers
SOURCE: what is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
Posted on Jan 17, 2010
joe_lishman
  • 192 Answers
SOURCE: Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
Posted on Jan 19, 2010
Hello, I have an AEG front load washing machine. It appears to be leaking water during the spin cycle as it is dripping off the bottom bolt that secures the 2 halves of the tub. Additionally on one side...
The drying cycle uses a very small flow of water all the time it's drying. When it's washing it uses a large flow of water initially and for each rinse.
If the problem's only when when drying then the one pipe it's using only for drying may be leaking. It feeds a plastic condensor bottle on the right side seen from the front. Hot air is blown upwards through the condensor and a leak can let water vapour condense on the inside of the case in that area.
Oct 05, 2013 | AEG Washing Machines
Aeg lavamat 54600 won't begin cycle
check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off you will see your pump undo the plastic screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Nov 02, 2012 | AEG Washing Machines
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
Have an Aeg oko 4020 dishwasher. Installed a new pump and it worked for awhile. It now won't switch off but the cycles do not run. Someone suggested there maybe water in some area that has caused some sort...
it probably has water in the bottom tray
take bottom front panel off and this exposes the bottom tray
mop out water and machine will run
if fault reoccure then you have a leak
Nov 29, 2008 | AEG Dishwashers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
AEG Favourit 446
Aug 11, 2008 | AEG 24 in. Favorit 40310 Free-standing...
AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Mar 24, 2008 | AEG Washing Machines
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Favorit 50500 Built-in Dishwasher Logo
44 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
