Question about Seagate ST3500418AS 500GB 7200RPM SATA 16MB FACTORY COD Hard Drive
Need a driver installation for ST3500418AS. when booting must enter the driver. Thanx be 4. :)
  • Brian Sullivan
    Brian Sullivan Mar 27, 2011
    what is the error code
ERROR LOADING OS
Posted on Dec 21, 2011
I just experienced my third ST3500418AS failure in 3 months. My disks are in RAID10 (1+0) configuration, so I've just been returning the drives, and the RAID rebuilds, but what's going on? I get...
Since you have so often problems, I suggest to take a look at the controller also (firmware etc). If it's possible use another one (in case of independent controller). A good idea is to check for hard disk firmware update from official seagate site.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | Seagate ST3500418AS 500GB 7200RPM SATA...
I need to instal - raid driver-
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configure as boot from cdrom.
3. restart machine Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floppy insert when winxp setup asking F6 for additional driver.
Jun 17, 2011 | ASUS P5RD1-VM Motherboard
I have a dell inspirion 560 desktop with a seagate barracuda 7200.12 500gbhard drive which failed, i replaced it with another one and its saying there is no bootable device and its hooked up just like...
1) All you need is a *bootable* Windows CD/DVD. 2) Go to your BIOS, choose First Boot device as 'CD/DVD Drive" 3) Second Boot device as HDD 4) Insert the bootable Windows CD/DVD into your CD/DVD Drive and install Windows from it.
Feb 06, 2011 | Seagate Barracuda 7200.12 ST3500418AS Hard...
My seagate sata 500gb barracuda 7200.12 ST3500418AS not booting.and showing black screen.I can`t install windows because no drive is showing .please help.
If your hard drive is an IDE type, the data cable that connects it to the motherboard will be a flat (usually gray colored) cable that has three 40 pin female connectors on it. If it is an 18" cable, the 2 connectors that go to IDE devices (hard drive or CD-ROM) will be spaced about 6" apart at one end of the cable and the connector that connects to the motherboard will be at the far end of the cable. Also, the cable will have a red stripe along one side of it. The stripe is an indicator of where pin # 1 is on the cable.
Since the IDE cable connects to two devices, there has to be a way for the motherboard controller to know what is connected to each connector. This is accomplished by small straps called jumpers on the rear of the IDE devices. The jumper choices are Cable Select (CS), Master (MA), and Slave (SL).
If your hard drive is strapped as master you must connect it to the connector at the end of the cable. ( If there is a second device on the cable it must be strapped as slave.)
If your hard drive is strapped as Cable Select it is usually connected to the end of the cable but any device on the 2nd connector must also be strapped as Cable Select.
Verify that the hard drive is strapped properly and then be sure it is connected to the drive with the red stripe side closest to the hard drive 4 pin power connector.
At the motherboard end, be sure the cable is connected with the red stripe side adjacent to pin 1. A "!" is usually marked on the motherboard next to the pin 1 of the IDE socket.
Verify that a 4 pin power connector is plugged into the connector on your hard drive and be sure it is fully inserted. .
If you have a SATA drive, the connections are easier. Verify that one end of a SATA data cable (usually red in color) is connected to your hard drive and the other to the first available SATA connector on your motherboard.. Then verify that a SATA power cable is connected to the power receptacle on your hard drive.
When you are sure your connections are correct, plug in and as you turn on your PC, hold down the delete key to enter BIOS setup. (On some machines it's the F!, F2 or F10 key).
Once in BIOS setup, first scroll through all the menus and make sure that all on-board IDE and SATA devices show that they are set for ENABLED or Auto (If you see DISABLED, change it to ENABLED.)
Then, press the Enter key to select the first display screen, ususally titled "Standard CMOS Features". Your Hard Drive should be listed under IDE or Sata devices. If it is, follow the on-screen instructions to get to the Boot Menu. If this hard drive is the device that you want to load your operating system from, be sure it is listed as one of the boot choices.
If the CMOS does not see your hard drive, then you need to have the drive and your PC tested by a PC technician to determine what the problem is.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Dec 19, 2010 | Seagate ST3500418AS 500GB 7200RPM SATA...
How to clean install windows 7 on toshiba a505-s6980
Hello ,
You have to first have the
*WINDOWS 7 DVD BOOTABLE
Go through the steps
1. First insert the dvd and restart your system for booting the
disc.
2. Then before booting the disc will ask for press any key to
boot the cd... press enter there.
3. Then the cd boots and gets into the setup process.
4. Select install and it shows the partition screen .
5. Select every drive and click the format option available there.
6. Then press enter on the particular drive for the windows 7
installation to start.
7. The installation starts and it automatically does everything
no need to worry about any process now.
8. After the windows gets installed, install all the drivers for your
notebook from the toshiba website as you have not provided
me the exact model of your laptop.
9. If you need a key for your OS you can mail me through
vky88@live.com
Aug 31, 2010 | Microsoft Computers & Internet
I want to dawnload windows xp
You can't just download software, that is illegal. You can purchase Windows XP in every computer shop.
Jun 17, 2009 | Acer Aspire 6920-6621 Notebook
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
My optiplex gx260
first of all u need one oparting system cd. windows xp or windows vista.put cd in cd rom and boot your pc from cd dvd in first screen booting options. then make partitions install step by step OS. when u complete go to dell web page search your computer model for download drivers for your oprating system like sound driver display driver modem and all hadwares.
now your computer is ready for use.
thanx
Sep 04, 2008 | Dell OptiPlex GX260 PC Desktop
How to install window's Xp in my system
firstly..u must have cd winxp..
after u boot computer,go to cmos and select boot sequence the cd first.
after that insert the xp cd into your laptop..and reboot..
select boot from cd...press enter..
select c: enter
select leave setup.. enter..
select c
and lastly enter..
and u just follow up the question ex:language
choose your region and your language n press enter..
happy trying..
good luck
Apr 17, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Major help needed
hi jtiker,
if you have replaced all the parts mentioned above then you will need to reinstall windows as it will try to use drivers from the old windows and create more problems for you.
go to the bios and set it to boot from the dvdrom first then reinstall windows.
your only other choice is to boot in safe mode and try to reinstall the mobo drivers....not recommended though
good luck
smeags
Dec 05, 2007 | ASUS A8V-E Deluxe Motherboard
Seagate ST3500418AS  500GB 7200RPM SATA 16MB FACTORY COD Hard Drive Logo
441 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
