Question about Lexi-Comp Institutional Application
I was trying to get the lexi-comp base icon off of my i phone 4 and just leave the lexi-comp institutional icon and I seem to have deleted my institutional programs. When I try to download the apps again it comes up " installed " but they will not come up on my device ? Help!!
Mobile Icon stays on but no messages.
turn the phone off then a few minutes later back on. works on mine anyway
Sep 06, 2016 | Cell Phones
What is a good nickname for my friend Lexie
Try this out from someone with a similar issues:
My name is Alexandria Arline, but everyone knows me as Lexie. I don't like it when people spell it "Lexi", it just doesn't seem finished to me. But I love my name, I've only met one person with the same name, ever. babynames allparenting com
Feb 09, 2015 | Computers & Internet
How exactly do you delete numbers on a cordless phone
Remove the battery over night & leave phone off Base stand if you want to delete ALL numbers (I'd unplug the phone line too to be sure in case your phone base has a memory chip, some do). To remove one or more numbers, Left click main button to bring up the phone list, bottom click to highlight the number you want to delete, click on SEL, then select Delete & press SEL again.
Jun 06, 2014 | Uniden 5.8GHz Cordless Phone
How do I listen to and erase message?
Are you trying to get the messages from the phone directly or by calling into your phone.
If the answering system is on, then you can play back the messages from the base by pressing the Play/Stop button.To delete a message from the base, press the Delete button (has a 0 with a slash through it) while the message is playing. To delete all messages, press the Delete button when the phone is in standby. From the handset press the Messages softkey (has an envelope icon) when the phone is in standby. Then press Play/2 to play back the messages. To delete a message, press Delete/4 while it is playing. (Deleting all messages can only be done at the base.)
If you are calling into your phone system, you need to have set a two-digit PIN from either the base or the handset and remember it. Then call the number for your phone from a touch tone phone, press 0 and then the PIN within 2 seconds. (Do this while your greeting is playing or after a series of beeps when the phone answers your call after 10 rings if the answering system was off.) If the system is off, start by pressing 0 6 to turn it on. Press 0 2 to play back the messages. (All commands need to be entered within 15 seconds of the last command finishing with both keys pressed within 2 seconds.) To delete a message, press 0 4.
Uniden has the manuals for most of their phones on their support site: http://www.uniden.com/scat/cordlessphones_mnl . Phones are listed in numerical and alphabetical order; thus the TRU9480 manual is on page 7. The direct link to the TRU9480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9480om.pdf .
I hope this helps.
Sep 01, 2011 | Uniden TRU9480 Cordless Phone
I have a mail icon on my uniden 6.0 homephone and can't figure how to open and delete it.
1.)On the base or phone, press MENU/SELECT. 2) Select the Global Setup menu, and then the VMWI Reset submenu. 3) Move the cursor to select Yes or No. 4) Press MENU/SELECT. You will hear a confirmation tone
Mar 05, 2011 | Uniden DECT 6.0 Cordless Phone ID
Voicemail icon will not go away after i delete my voicemail how can i get that to go away?
This happens to me A LOT. It seems to help to delete voicemail messages when I have more than 3 signal bars. To get rid of the Icon you have to leave a voicemail on your phone, use someone elses phone and just leave a message, it should vibrate like it has a new voicemail but the count shouldn't go up, then just delete the message when you have close to full bars.
May 21, 2010 | HTC Touch Pro2 Smartphone
LG Vu voicemail icon will not leave screen
call your phone from another phone and leave yourself a new message, then go in and delete that message, it worked for me
Jul 24, 2009 | LG Vu CU920 Cellular Phone
Hi My cordless phone does not receive or make calls anymore. I have checked and everything seems to be working OK. There is a small icon that appeared on the screen ,like a battery,, and is all black
The battery indicator on the handset tends to be misleading. You may need to replace the battery, or if the phone is under a year old, try charging over night. Simply unplug from the phone jack, leaving base plugged into power.
Apr 18, 2009 | Lands Phones
Phone icon to open up contacts and keypad crashes
whew!! just fixed it!!! i dnt knw if it'll work on your but it worked on mine.. just try it.. click installer then click sources then i saw this invalid source and just deleted it and restarted my phone..
Dec 15, 2008 | Apple iPhone Smartphone
Voicemail icon won't go away.
I've had the same problem as well. I made sure no messages were there, then called and left myself a message from another phone. I went in and listened to the message and waited till the option to delete came on and for the indication there were no more messages. Icon was gone.
Aug 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Lexi-Comp Institutional Application Logo
107 people viewed this question
Top Lexi-Comp Apps Experts
Bill Boyd
ray gallant
Are you a Lexi-Comp App Expert? Answer questions, earn points and help others
