Question about Dryers
Beko drvs73w dryer keeps breaking belts. Drum seems to jam at door end and motor contines to melt the belt.The bearings are good . The dryer is only 18 months old. Every time belt breaks when I investigate it the drum is jammed at door end . Help. Cheers
  • Anonymous Mar 18, 2014
    have replaced the fuse used different socket but no power at all it only 20 months old
    President:
  • 3,074 Answers
Check your drum rollers/glides and your idler arm(it is suggested to change this with the belt), here is a website hope it helps,Tim:
http://www.partselect.com/dryer+inspect-pulley+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on Mar 27, 2011
Drum not turning on beko dryer
  • I am not familiar with Beko Dryers, but they all operate on the same principle so let me see if I can steer you in the right direction. Can you turn the drum by hand? Is it free turning with just a bit of resistance? If not, the drum may have come off the felt pads or track and is binding up, or the motor is bad and the drive pulley bearings have frozen.
  • If the drum turns freely by hand, then there are a few things to check. The drum will not turn if a safety circuit is open. This is or could be the dryer door switch. This switch has to be closed for the dryer to think the door is shut and therefore will start the drum turning. Try pushing/holding the latch for the door switch in and then push start. Be careful not to get anything like the clothing you are wearing caught in the open door.
  • Perhaps you can hear the motor run when you push the start button but the drum does not turn. This would indicate that the drive belt broke or came off the drum/motor pulley. In this case you would need to replace the belt as it may have stretched and is now too long. I hope one of these helps..Good Luck!
Feb 13, 2015 | Dryers
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
Hot point dryer
the drum has dropped
the drum is suspended on felt pads to seal the drum edges, nylon guides at the front, and rubber tyred thrust rollers to withstand the torque of the motor and belt at the rear.
the usual cause is the rollers have failed, common fault, easy fix, cheap too
good rollers look like this
1ac2db2.jpg worn rollers like this
try not to run the dryer till the rollers are replaced, the extra strain will break the belt,
  • raise case lid
  2. pull tensioner fully agains spring
  3. remove belt from motor pulley
  4. lift drum and withdraw fully forwards
  5. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear
reassemble.
  1. loop belt loosely around drum at wear marks from prior installation
  2. reinsert drum onto rollers bearings slides felts as installed.
  3. loop belt around motor pulley
  4. pull tensioner pulley against spring to end of its travel
  5. loop belt around tensioner pulley
  6. relax tensioner pulley to tighten belt
  7. rotate drum by hand to ensure belt is aligned
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • raise case lid
Notes
May 07, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
438 people viewed this question
Top Dryers Experts
