Ok i have a gate way 6520gz and when i boot it up it load the bios ond stuff normally and the mother board is not bad but once the bios is done loading and **** the computer shuts off could it be a HDD failure.
  • Jonathan S
    Jonathan S Mar 27, 2011
    Are you getting any beep codes when it is booting or any messages stating HDD not detected?
  • 11,800 Answers
Simple test: disconnect the hdd and see what happens. If the pc no longer shuts down then yes, the hdd has died.
Posted on Mar 27, 2011
Have an HP pavilion G7 wont boot, no power light , replaced mother board, still wont boot. Removed battery plugged in a/c cord still no boot? Help?
G7 what, it has full model number not just G7,
that means near zero. in fact.
what does boot mean? its a long serial process.
sure no windows (no windows stated, XP?)
the power must turn on and first.
hear that fan run? feel it blow? vents clean first.
The G7 Pavilion is both a desktop PC and a Laptop,
silly no, but HP did that, google G7 , SEE?
I guess the BATTERY thing is not the CMOS battery but the huge , Laptop battery. smart act taking it out first. they do short.
but what about sound, and the fan blowing. it must blow
or the Power pack is dead.
i bet the old mother board was ok. and you didnt do the strip down test to prove that.
ever heard of these?
1: CMOS RTC BIOS NVRAM COIN cell, replace it first.
if not the BIOS can not load configs. ever. again. bad bad bad.
2: power pack dead if fan is dead. replace it its only $8
or use a voltmeter is it enters the mobo 19vdc, is ok, less that 18v not.
3: then if the fan is still dead, power dead, BIOS dead.
and external VGA port dead to external monitors, then
we pull modules off the MOBO, up to 6 or more
they all can short and when they do, power goes to ZERO
the regulators do that by DESIGN.
(the no catch fire deal)
sure wish you said (lap or desk top sure did)
after all the Desktop PSU may be bad, if its fan is dead.
Nov 12, 2017 | HP Computers & Internet
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
Pc won't boot up
pls check ram
fix it other slot
Dec 06, 2013 | Computers & Internet
Ok turn my gate way 6520gz on it does its bios screen normally then it goes to the screen where i would press f11 for system restoration like normal, then it just shuts down. battery fully charged, mother...
Yes it may be. When you cut it on will your Cap Lock light come on? If it does most likely it is your Hard Drive. You also if you have a system bootable disk place it in your CD-Rom and see if you system boots to it. If it does then your hard drive has a failure or a Virus has ate your boot sector.
Mar 27, 2011 | Gateway Computers & Internet
Powers on, Fan runs at high for 10Sec's then goes off, but no OS loading nor any visual activity on the Display.
your screen may be broken.
Do you see the BIOS message at the beginning of the boot up? If you don't, then the screen or the video card/circuit is dead
Mar 18, 2010 | Gateway 6520GZ Notebook
I have 845 mother board of intel. when i boot my computer, it shows f1 for bios entry. when i enter f1, it goes inside bios but after that my keyboard will not work. please help me.
its problem bios not configure properly reset mother board jumpure 1-2 normal 2-3 reset again position 1-2 machin is on press F2 set up bios your choice configure before unpluged your hard drive
Nov 21, 2009 | Intel Motherboard
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
Problem on Boot
Hello tccat1,
Definitley sounds like a bad motherboard, however, try removing the memory and using a different stick if you have some. Maybe 512 see if you can at least get it to post.
Nov 14, 2008 | MSI K9MM-V Motherboard
Intel PENTIUM-4 865GV CHIP... Problem
check to see if the jumpers for the bios is set to normal boot
Aug 14, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
