Question about Panasonic Televison & Video
My panasonic plasma th42pv30 wont start blinks 9 times on red standby light any suggestions to the faulty board?
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
  • 534 Answers
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Posted on Jun 05, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
I have a 2009 panasonic tc-p58v10 Viera plasma tv. No video and the red light is blinking 9 times. I just put a refurbished A board in it. Any ideas?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 29, 2016 | Panasonic TC-P58V10 Plasma TV
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
Oct 06, 2016 | Panasonic Viera TC-P55UT50 55" 3D 1080p...
Panasonic plasma tv led blinks 12
Aug 24, 2016 | Panasonic TC-P46G15 Plasma TV
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Is the Panasonic TC-P42C2 supposed to have a flashing red light that suggests which board is the problem? If there is no red light, what does it suggest?
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 20, 2014 | Panasonic Televison & Video
Blinking red light on TV
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Jul 09, 2017 | Panasonic TH-50PH9UK 50 in. Plasma...
PANASONIC PLASMA HD 42 INCH WONT TURN ON JUST BLINKS 10 TIMES
10 blinks of standby light with Panasonic Plasma indicates:
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
For more details visit the site named [Electro-help" The keyword to search is "Electronicshelponline"
Jul 03, 2012 | Panasonic TCP42C2 42 in TV
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
