Question about Cycling
The seat has come lose and the bolt is not catching on anything so the seat is not secure
  • 206 Answers
Please replace the bolt and nut of the seat with a new one and add washer in order to tighten the seat as required.
Posted on Mar 27, 2011
Remove front passenger side seat
Need more info on year, make and model. Older vehicles have four (4) mounting bolts that usually need metric socket with half inch drive ratchet. Newer vehicles only have back bolts to remove and the seat will rock forward to lift up and out of catch mount.
Dec 16, 2014 | Seat Cars & Trucks
2010 GSXR 750 change exhaust headers, put in dyno and auto tuner but i notice when start petrol flying out of exhaust and one of the header pipes are cold checked all connections and are fine It starts ok...
Instructions
    • 1 Remove the rider's seat, using an Allen socket to unscrew the pair of bolts that secure the rear of the seat to the frame. Lift the rear of the seat upward then pull the seat toward the rear of the motorcycle to disengage it from the frame's catch tabs.
    • 2 Remove the pair of bolts that secure the front of the gas tank to the frame. Lift the fuel tank upward on the pivot at the base of the tank. Support the fuel tank against the frame using the tank's support rod.
    • 3 Remove the air box. Pull the three air hoses from the air box. Loosen the clamps on the air box's rubber boots with a screwdriver, and pull the air box out of the motorcycle.
    • 4 Pull the four coil packs out of the motor's cylinders. Clear any dirt and debris that has accumulated on top of the cylinders with compressed air, directing the air into the spark plug holes that the coil packs were installed in. Remove the spark plugs using a spark plug socket attached to a socket extension.
    • 5 Install new, properly gapped spark plugs into the motor with a spark plug socket. Tighten the socket until it is seated firmly against the motor. Reinstall the coil packs onto the spark plugs.
    • 6 Reinstall the air box, tightening the clamps on the rubber boots to secure the air box to the throttle bodies. Reconnect the trio of air hoses to the air box.
    • 7 Remove the tank support rod and lower the fuel tank onto the frame. Insert and tighten the fuel tank bolts with an Allen socket. Reinstall the seat, firmly tightening the mounting bolts with an Allen socket.
Jan 16, 2013 | 2010 Suzuki GSXR750
Where r the plugs on gsxr750t srad plz
  • Oct 25, 2011 | Motorcycles
    How to open the seat
    If it is any thing like my 1980 Yamaha, then there are two bolts loosely swinging from the seat down to a catch bracket mounted on the frame about two thirds back from the front. Loosen those two nuts enough to swing the bolts out of the catch,lift and separate the seat from the frame. Many seats are attached this way.
    May 17, 2011 | Yamaha XT 125 X Motorcycles
    How to repair front driver side widow motor.at fir st there was a grinding sound that made me think it was off track. now its not doing anything. motor works all the way up and down but glass doesnt move.
    {: ) Sounds like you have a faulty window regulator. Usually the regulator cable gets broken or detached. If this is the case, your window may not move at all, even though the motor seems to be working when you switch the button up or down.
    The door trim panel need to be removed totally. Once removed, you will find two bolts for the glass catch, 3 bolts for the motor, and 4 bolts for the regulator.( all #10mm )
    Begin by loosening the 2 bolts on the rubber insulated glass catch, just enough to pull the glass up from its track. You may need an assistant. You need to lift the glass (only) to the top closed position, and apply a strong masking tape to hold the glass on that position for the time being.
    Continue by removing the motor and regulator bolts. I hope the replacement part is readily available. I think the window regulator comes in assembly, the motor is integrated to the regulator.
    When bolts removed, simply pull out and fold to remove outwards. Be sure you remember how it was mounted before you removed it.
    Installation is just the reversal procedure. Position first the regulator assembly and semi-tight all the bolts. Its better if you just follow the old bolt markings. Secure motor connection.
    Loosen the two bolts on the glass catch, just enough for the glass to slide and seat freely. Temporarily connect the window switch. Press the up button slowly and align the glass with the catch. When glass seated fully, tighten the 2 bolts on the catch to hold it firmly. You can remove now all the tapes you sticked.
    Try to operate the window up and down carefully and observe. Make that final tightening of the regulator with the glass resting in the the full up position. Re-install the trim panel. Goodluck.
    Nov 17, 2010 | 2008 Chevrolet Suburban
    I do not know how to remove front seat from a 1994 chevrolet beretta cp
    hmm,, ok,, try this..
    1.) look under the seat you will notice two sliding rods,, on this there are 4 brackets with bolts.. its maybe hidden under the upholestry,, any way remove the bolts,, slide any lift seat..
    Oct 12, 2010 | Chevrolet Beretta Cars & Trucks
    Drivers seat how do i take it out 2005 malibu drivers seat is sagging on the right rear
    pry off any plastic bolt covers where the bolts secure the seat
    pull 4 bolts securing seat to vehicles floor pan
    Disconnect negative battery teminal,
    disconnect any electrical plugs going to the seat
    pull out drivers door opening
    Aug 19, 2010 | 2005 Chevrolet Malibu
    I pried the back seat up but it doen't come loose.
    there is a bolt on each side of the seat center to the backside and a insert on each side in the front as well in which they catch to keep the seat in place ....and a bolt each side for the back part of the seat the same way ... pull forwards on the back of the seat and remove the 2 bolts and lift up from the back to remove ...
    Dec 21, 2009 | 2004 Cadillac Deville
    How to fit carry cot to car
    I assume you are referring to the Matrix Pro Car Seat that lays flat? You can fit this in two different ways. To fit it sitting upright, make sure it is in the most upright position and facing the back of the car. Pass the lap belt underneath the car seat itself, through the blue catches, then plug it in. The long part of the seat belt goes around the back of the car seat through the blue catch nearest you. Pull it all really tight and it should be more secure. To fit the car seat laying flat, this depends on your car. It needs to use two 3 point seat belts. 2 point seat belts don't work. Plug in both seat belts, and pull the lap belt part through the silver catch on both side. Pull as tight as you can. To make car seat fitting more secure, try placing a slip mat like the Sunshine Kids Grip It or Super Mat underneath to hold it in place. These are all crash tested and safe.
    Sep 12, 2009 | Baby Gear
    Remove the seat
    First, remove the pillon seat behind the driver seat. Use a metric socket wrench to remove the mounting bolt at the back center of the pillon. Note the 'retaining strap' over the pillon. You can remove one of the side screws that hold this strap and swing it aside, but this is not absolutely necessary. Once the pillon mounting bolt is out, lift the pillon slightly and pull it to the rear. Be careful not to let metal parts scratch your rear fender. Now look at the hex socket bolts holding the driver seat to the rear fender. These are removed with a metric hex wrench (Allen wrench). Don't mess with these unless you can fit the bolt socket exactly. There should be a hex wrench in your Vulcan toolkit. When these have been removed, the driver seat can be lifted up and back to remove. It's a real mess under there, isn't it? To re-install, reverse the order of the above -- driver's seat goes in first, bolts secured and then the pillon. Don't force anything. If either seat is hanging up above its mounting position, you don't have the seat 'tongue' in its socket.
    Nov 10, 2008 | 2004 kawasaki VN 1600 Mean Streak
    Cycling Logo
    Top Cycling Experts
    Michial Gueffroy
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
