When voltage fluctuates my ups restarts my computer what is the fault in my ups. tell me the solution
    New Friend:
  • 12 Answers
It could be the battery and it could be the control
Posted on Oct 02, 2015
  • 122 Answers
Hello, The problem is with the battries in side. I think you have to look for where the battry is sold(Ups Battries Only). then install it and try again.
Posted on Mar 27, 2011
Temperature gauge keeps fluctuating whats the cause
Fiats have a reputation for electrical/electronic problems as they age and even when they are not very old they can manage strange things that even sometimes defeat the dealers, though the same can be said of many modern vehicles. I used to look after a Ducato motorhome and fortunately didn't need to get involved with much electrical work - the only faults were caused by the coachbuilders rushing around and being careless and not by Fiat.
I am not sure if the temp gauge is driven by the engine management or is a traditional circuit but either way the temperature gauge is in effect a voltmeter of sorts. Assuming the gauge is ok, the reading will only fluctuate if the voltage in the circuit fluctuates and that could mean the supply voltage is fluctuating or the resistance of the ground path is fluctuating.
With the traditional circuit the gauge is supplied by an electronically stabilised voltage and the ground path resistance is varied by the engine coolant temperature sensor and fluctuations could be anything from a faulty instrument voltage regulator, through faulty wiring or connections to the temperature actually fluctuating.
If the gauge is driven by the engine management the same approximately applies but checking the circuit becomes much more complex due to the need for circuit diagrams and specialised test equipment, though these would not be needed just to check the security of the gauge in the printed circuit of the instrument panel.
Mar 18, 2017 | Fiat Cars & Trucks
Idle fluctuates on 1995 f250, sometimes dies, sometimes revs, no apparent vaccum issues, IAC with scan tool reads low voltage issue. Could this be vaccum, charging system, faulty computer? Problem is...
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 08, 2012 | 1995 Ford F250
Haier 21 inch CRT TV picture getting distorted due to voltage fluctuation which component has to replace?
The picture tube is affected by the focus voltage from the flyback, if the voltage is fluctuating, it can be caused by the picture tube or the flyback transformer, the most likely is the high voltage transformer.
Mar 10, 2012 | Computers & Internet
I was having many problems with my W3107 Microsoft Windows XP Home Edition Emachine. I thought a system recovery would help it, alot. Well after I did the system recovery 3 times the same thing kept coming...
Is it new-enough to still be under WARRANTY?
Your problems could either be:
* bad RAM -- on another computer, download the free 'MEMTEST86+' software, and burn it to a CD-recordable disk. Reboot your computer, and tell it to boot from the CD, to do an exhaustive test.
* bad motherboard -- bulging or leaking capacitors cause "random" voltage-fluctuations, and other "random" problems. Your only option is to replace a "bad" motherboard, or to buy a new computer.
* bad disk-drive -- not storing data 100% correctly.
Diagnosing these problems is best left to a qualified technician -- take your computer to one.
P.S. Telephone eMachines -- they can courier-ship you a replacement set of "System Recovery" CD-ROM disks.
Feb 21, 2011 | Computers & Internet
I have an LG split system air conditioner model number LSZ244VN-4 it is coming up with a fault code of CS after it has been running for approx 5 minutes
There is no CS code. Please read as C5.
Fault Code 05 and 53 (CH05 is displayed at indoor unit, 53 is displayed at outdoor unit)
This fault code indicates a communication error between the indoor and outdoor units; this is usually caused
by wiring errors or condensate pumps connected to the inter-connecting cable.
The communication between the units is a fluctuating DC voltage commonly called a serial signal, it can be
easily lost if the wiring is not done correctly. If there is a communication error fault CH05 will appear within 5
mins of powering up the system.
Testing
• Check Outdoor and Indoor Power Supply Voltages ( 230V ±10% ) and correct as necessary.
• Check for any mis-wiring or loose connections and correct as required.
• Check the resistance between communication line and GND. (Normal: Over 2M).
• If one Indoor unit operates normally Outdoor PCB is generally normal.
Turn on the power and start the indoor unit in cooling, set the temperature to 18ºC; the serial communication
signal will only be present for the first 3 mins of operation.
Set your meter to DC Volts, Test between terminals 5 (Red probe) and 2 or Earth (Black probe) of the outdoor
unit, you should see a fluctuating 0-72 Vdc.
If the Voltage is not present disconnect the terminal 5 cable, test the Voltage between this wire (Red probe)
and 2 or Earth (Black probe), you should see a steady voltage in the range of -0.1 to -10.0 Vdc. If No Voltage
is present either the cable or Indoor PCB must be faulty. This can be determined by checking the voltage
output on the Comms terminal of the Indoor unit, with the Comms wire disconnected. If No Voltage is present
the Indoor PCB must be faulty, if present, cable must be at fault.
Jan 19, 2011 | Heating & Cooling
I have a LG Inverter Art cool and after about 5 minutes it stops and C5 shows on the panel Kerrie
Fault Code 05.
Testing
the Indoor PCB must be faulty, if present, cable must be at fault. Helpful?
Jan 19, 2011 | LG Art Cool LA121CNP wall/window Air...
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Fault code po420 ; is problem sensors or is it the cat conv
The only thing that will set this code is the catalytic converter or the oxygen sensor behind it. Way to tell if it is the sensor is to monitor voltage reading with scan tool and see if it is fluctuating the same as the upstream oxygen sensor. If it is the converter is "free flowing" and will have to be replaced. If the sensor is "flatlined" then it is most likely bad and setting the code.
Apr 30, 2009 | Ford Fusion Cars & Trucks
Computers & Internet Logo
335 people viewed this question
David Payne
David Payne
