Question about Sony BDVE300 Theater System
My sony bdv-e300 started not being able to read discs.....after trying updates (from .007 to .009); resetting; unplugging from surge protector to wall outlet (all Sony's support ideas).....nothing worked....it now simply says "no disc" whenever you insert one. A friend and a sales assoc. at Best Buy suggested I run a clean disc, however the Sony manual does not recommend this.......please help with suggestions. Tee.
Same problem here Jeff i cant get any blu rays to play that used to play since upgrading firmware from 009 to 011 it simply say's No disc DVD's are fine ...
Posted on Nov 28, 2011
Did you figure this out? I upgraded firmware from 009 to 011 and am now having the same problem. Have had the unit for 18 months. Called Sony and they want me to ship in for 147.00 dollar repair even though their firmware upgrade caused the problem. Cannot operate disk now when trying to load a Blu-ray disk. Plays standard DSD's without any trouble.....
Posted on Nov 15, 2011
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
BDV-E580
There have been problems with firmware updates, go online to Sony and contact customer support and the technical department for answers. It is pointless when you must reset the processor constantly
Apr 20, 2012 | Sony BDP-S300 Blu-Ray Disc Player
I have a playstation 2 system that had a game in it, and was plugged into a surge protector. While the game was in the system the surge protector blew. Now when ever i put only that certain game that was...
Make sure that the disc is clean and there aren't any fingerprints or visible scratches on it. The disc may have been damaged by the console's laser during the power surge, so look for any deformations in your disc or anything that looks irregular. If you find one and you can't wipe it off, then your disc may be damaged beyond repair.
As a last ditch effort, if you do find a scratch or gouge in your disc, you can try using a little bit of clear nail polish to fill in the scratch. If that doesn't work, then you'll have to replace the disc.
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
Hi! how can i unlock my sony BDV-E300. It's reading only CD region 2. But I need the zone 1, 2, and 4. Thanks for any answer!!
I used the SONY Blu-Ray hack with the one-for-all remote (7730) and it worked OK:
Sony BDP-S350/S550/S5000ES DVD Multi-region hack - all4one remote 'Forum Bike'
I selected the BD/DVD function after Standby, pressed the 1-5 buttons as per the instructions, and the 24p indicator flashed. After switching to Standby & back again, it played a R1.
Try this, found it on another forum whilst awaiting help on a problem myself. fingers crosses doing helps me as well.
By the way, two users out of two who tried this both said it works.
Good luck
Nov 03, 2010 | Sony BDVE300 Theater System
Sony BDV-E300 doesn't open Tray
See the below side of the set there is a hole use hair pin to eject your disc.Do not too much force on it other wise you will broken any part.
Oct 30, 2010 | Sony BDVE300 Theater System
My daughters xps 200 won't start, she presses the button and nothing. She has checked the surge protector that it is pluged into and it is OK... is there a reset button is there was a power surge??
most surge protectors have some sort of on/off switch and a reset button. If there was a surge then you would need to pres the reset button to get the surge protector to function again. If there was no surge then try using the on/off switch on the surge protector to see if that helps. Also try simply unplugging the power cord from the back of the desktop while the computer is turned off. This will sometime also help.
Oct 12, 2009 | Dell XPS 200 PC Desktop
Keep saying No Disc on Sony BDV-IS1000
a lens dosent work. you need to buy more
Sep 28, 2009 | Sony DAV-IS10 System
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Sony BDVE300 Theater System Logo
508 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
