Cars & Trucks Logo
Posted on Mar 27, 2011
Why my vios 2006 model have sound of metal knocking.i replace the cylinder head,timing chain,chain guide,chain tensioner for a new one?
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Mar 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
4396
Points
45
Does it sound like heavy metal ? check main bearings / rod bearings? does oil pan have dents in it, could be hitting the crank?
How do I set timing on a 2.3 Suzuki aerio engine
wow no job stated.
04 (2.3L) ill take a wild guess and say, you might be fiddling the cam
and doing something there, new cam, new lifters, new chain, new head, ? what?
FSM means factory service manual, ever heard of one?
the FSM is just lousy 4 bucks why not read that first. and not mess it up.
https://suzukipitstopplus.com/Products/1004-2004-aerio-service-manual.aspx
you said SET, so i can only assume its all apart. right then
you want to Instal the chain and time it, right so here are the fsm steps
no photos. log in and read the FSM for that.
  1. Check that match mark on crankshaft timing sprocket is in match with timing mark on lower crankcase.
  2. Install crankshaft timing sprocket as shown in figure.
  3. Apply oil to bush of idler sprocket and install idler sprocket and sprocket shaft.
  4. Install first timing chain by aligning dark blue plate of first timing chain and match mark on idler sprocket.
  5. Bring yellow plate of first timing chain into match with match mark on crankshaft timing sprocket.
  6. Apply engine oil to sliding surface of timing chain tensioner and then install it as shown in figure. Tighten tensioner nut to 18 ft. lbs. (25 Nm).
  7. With latch of tensioner adjuster No.1 returned and plunger pushed back into body, insert stopper into latch and body. After inserting it, check to make sure that plunger will not come out.
  8. Install timing chain tensioner adjuster No.1. Tighten the timing chain tensioner adjuster No. 1 bolt to 8 ft. lbs. (11 Nm).
  9. Pull out stopper from adjuster No.1.
  10. Apply engine oil to sliding surface of timing chain guide No.1 and then install it. Tighten guide bolts to 6.5 ft. lbs. (9 Nm).
  11. Check that dark blue and yellow plates of first timing chain are in match with match marks on sprockets respectively.
  12. Install second timing chain as follows:
    • Check that match mark on crank timing sprocket is in match with timing mark on lower crankcase.
    • Check that arrow mark on idler sprocket faces upward.
    • Check that knock pins of intake and exhaust camshafts are aligned with timing marks on cylinder head.
    • Install second timing chain by aligning yellow plate of second timing chain and match marks on idler sprocket.
    • Install sprockets to intake and exhaust camshafts by aligning dark blue plate of second timing chain, match marks on intake sprocket and exhaust sprocket respectively. NOTE As an arrow mark is provided on both sides, camshaft timing sprocket has no specific installation direction.
  • Install intake and exhaust camshaft timing sprocket bolts. To install it, fit a spanner to hexagonal part at the center of camshaft to hold it stationary. Tighten the camshaft timing sprocket bolt to 57.5 ft. lbs. (80 Nm).
  • Push back plunger into tensioner body and hold it at the position by inserting stopper into body.
  • Install timing chain tensioner adjuster No.2 with new gasket. Tighten the timing chain tensioner adjuster No. 2 bolts to 8 ft. lbs. (11 Nm) and No. 2 nut to 33 ft. lbs. (45 Nm).
  • Pull out stopper from timing chain tensioner adjuster No.2.
  • Turn crankshaft two rotations clockwise then align timing mark on crankshaft and timing mark on cylinder block.
  • Check that timing marks of cylinder head and cylinder block are in match with match marks on sprockets respectively.
  • Apply oil to timing chains, tensioner, tensioner adjusters, sprockets, and guides.
  • Install timing chain cover. Reverse removal sequence to install timing chain cover noting the following points:
    • Apply sealant "A" and "B" to area as shown.
      • "A": Sealant 99000-31250
      • "B": Sealant 99000-31140
    • Apply sealant amount to the following areas.
      • "a": 0.12 inches (3mm)
      • "b": 0.08 inches (2mm)
      • "c": 0.24 inches (6mm)
      • "d": 0.63 inches (16mm)
      • "e": 0.55 inches (14mm)
      • "f": 2.56 inches (65mm)
      • "g": 2.87 inches (73mm)
      • "h": 0.16 inches (4mm)
    • Apply engine oil to oil seal lip, then install timing chain cover. Tighten bolts and nut to 8 ft. lbs. (11 Nm).
      NOTE Before installing timing chain cover, check that pin is securely fitted.
    • Before installing timing chain cover, check that pin is securely fitted.
  • Install alternator belt idler pulley. Tighten nut to 30.5 ft. lbs. (42 Nm).
  • Install alternator belt tensioner. Tighten bolts to 18.5 ft. lbs. (25 Nm).
  • Install water pump pulley.
  • Install A/C compressor bracket (if equipped). Tighten bracket bolts to 40 ft. lbs. (55 Nm).
  • Install cylinder head cover with new gaskets and seal washers and tighten nuts to 8 ft. lbs. (11 Nm).
  • Install oil pan.
  • Install crankshaft pulley using pulley holder tool. Tighten the crankshaft pulley bolt to 108.5 ft. lbs. (150 Nm).
  • Install engine assembly.
  • Install all remaining components in the reverse order of the removal procedure.
did that cover it, surely not.
but if you get the FSM and read it or log in , you will not miss the photos and the complex sealing bs on this motor.
How do i reset the timing on 2001 2.7l concorde if the chain was replaced and the timing is off
Did you take pictures while removing the originals? It's always a good habit. Below are the instructions you need to follow. Your own pics are very helpful when doing a big job like this.
  1. Disconnect negative battery (1) cable.
  2. Drain cooling system.
  3. Remove upper intake manifold.
  4. Remove cylinder head covers, crankshaft vibration damper, and timing chain cover.
CAUTION: When aligning timing marks, always rotate engine by turning the crankshaft. Failure to do so will result in valve and/or piston damage.
117014297
  1. Align crankshaft sprocket timing mark to mark on oil pump housing (2). The mark on oil pump housing is 600 ATDC of #1 cylinder.
CAUTION: When the timing chain is removed and the cylinder heads are still installed, DO NOT rotate the camshafts or crankshaft without first locating the proper crankshaft position. Failure to do so will result in valve and/or piston damage.
117016938
  1. Remove primary timing chain tensioner retainer cap (2) and tensioner (1) from right cylinder head.
117016939
  1. Disconnect and remove camshaft position sensor (4) from left cylinder head.
  2. Remove timing chain guide access plugs (3) from cylinder heads.
NOTE: When camshaft sprocket bolts are removed, the camshafts will rotate in a clockwise direction.
  1. Starting with the right camshaft sprocket, remove the sprocket attaching bolts. Remove camshaft damper (1) (if equipped) and sprocket.
  2. Remove left side camshaft sprocket attaching bolts and remove sprocket.
  3. Remove lower chain guide (7) and tensioner arm (8).
  4. Remove the primary timing chain (5).
  5. Remove crankshaft sprocket (6).
INSTALLATION
117016940
  1. Inspect all sprockets (4,9,11) and chain guides (2,5,10). Replace if worn.
  2. For crankshaft sprocket installation procedures Refer to CRANKSHAFT SPROCKET.
  3. If removed, install right and left side short chain guides (11). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
  4. Align crankshaft sprocket timing mark to the mark on oil pump housing (3).
NOTE: Lubricate timing chain and guides with engine oil before installation.
  1. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links (1).
117016941
  1. Lower the primary chain with left side sprocket through the left cylinder head opening.
NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
  1. Loosely position left side camshaft sprocket over camshaft hub.
  2. Align timing (plated) link to the crankshaft sprocket timing mark (3).
  3. Position primary chain onto water pump drive sprocket (10).
  4. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain (8) and loosely position over camshaft hub.
  5. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
  6. Install left side lower chain guide (2) and tensioner arm (5). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
NOTE: Inspect O-ring on chain guide access plugs before installing. Replace O-ring as necessary.
  1. Install chain guide access plugs to cylinder heads. Tighten plugs to 20 Nm (15 ft. lbs.) .
NOTE: To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
117016942
  1. Purge oil from timing chain tensioner using the following procedure:
    1. Place the check ball (2) end of tensioner into the shallow end of Special Tool 8186 (3).
    2. Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
117016943
  1. Reset timing chain tensioner using the following procedure:
    1. Position cylinder plunger (4) into the deeper end of Special Tool 8186 (3).
    2. Apply a downward force until tensioner is reset.
NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball.
CAUTION: Ensure the tensioner is properly reset. The tensioner body (4) must bottom against the top edge of Special Tool 8186 (3). Failure to properly perform the resetting procedure may cause tensioner jamming.
NOTE: Inspect the tensioner O-ring (2) for nicks or cuts and make sure the snap ring (1) is correctly installed, replace as necessary.
117016944
  1. Install the reset chain tensioner (1) into the right cylinder head.
  2. Position tensioner retaining plate (2) and tighten bolts (1) to 12 Nm (105 inch lbs.) .
117016945
  1. Starting at the right cylinder bank, first position the camshaft damper (1) (if equipped) on camshaft hub, then insert a 3/8 square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 inch lbs.) .
  2. Turn the left side camshaft by inserting a 3/8 square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 inch lbs.).
  3. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
117016946
  1. Activate the timing chain tensioner by using a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then release the tensioner arm. Verify the tensioner is activated (extends).
117016947
  1. Install camshaft position sensor (2) and connect electrical connector.
  2. Install the timing chain cover, crankshaft vibration damper, and cylinder head covers.
  3. Install upper intake manifold.
NOTE: After installation of a reset tensioner, engine noise will occur after initial start-up. This noise will normally disappear within 5-10 seconds.
  1. Fill cooling system.
2answers
Need timing gear marks for 2004 Kia Sadona 3.5L engine
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes.
    Kia_Sedona_2002-2006
    Timing Chain, Sprockets, Front Cover & Seal
    Print
    3.8L Engine
    3. Remove the engine from the vehicle.
    4. Remove the drive belt. Remove the power steering pump. Remove the air conditioning compressor.
    5. Remove the alternator. Remove the drive belt idler. Remove the drive belt tensioner. Remove the water pump pulley. Remove the intake manifold.
    6. Remove the connector bracket from the left cylinder head cover. Disconnect the right ignition coil connector, condenser connector and remove the bracket.
    7. Remove the left cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    8. Remove the right cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    9. Set the No. 1 cylinder to TDC on the compression stroke. Turn the crankshaft pulley and align its groove with the timing mark T of the lower timing chain cover.
    10. Check that the mark of the camshaft timing sprockets are in straight line positioning on the cylinder head surface. If not rotate the crankshaft 360 degrees. Do not rotate the engine counterclockwise.
    11. Remove the oil pan. Remove the crankshaft damper pulley. Remove the timing chain cover.
      NOTE Be careful not to damage the contact surfaces of the cylinder block, cylinder head and timing chain cover. Before removing the timing chain, mark the right and left timing chains with an identification mark based on the location of the sprocket because the identification mark on the chain for TDC can be erased.
    12. After compressing the timing chain tensioner, install a set pin. Remove the right cam to cam guide. Remove the right timing chain auto tensioner and timing chain tensioner arm.
    13. Remove the oil pump chain cover. Remove the oil pump chain tensioner assembly. Remove the oil pump chain guide. Remove the right timing chain.
    14. Remove the right timing chain guide. Remove the oil pump chain sprocket and oil pump chain. Remove the crankshaft sprocket, oil pump and camshaft drive gear.
    15. Remove the left cam to cam guide. Remove the left timing chain auto tensioner and timing chain tensioner arm. Remove the left timing chain.
    16. Remove the left timing chain guide. Remove the crankshaft sprocket and left camshaft drive. Remove the tensioner adapter assembly.
      Fig. Timing chain and related components-3.8L Engine
    To install:
    1. Check the camshaft and crankshaft sprockets for wear and damage, replace as required.
    2. Inspect the tensioner arm and chain guide for wear and damage, replace as required.
    3. Check that the tensioner pin moves smoothly when the ratchet pawl is released with a thin rod.
    4. The key of the crankshaft should be aligned with the timing mark of the timing chain cover. This indicates that the piston is at TDC on the compression stroke.
    5. Install the tensioner adapter assembly. Install the crankshaft sprocket and left camshaft drive.
    6. Install the left timing chain guide and torque the retaining bolts 14-18 ft. lbs.
    7. Install the left timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, timing chain guide, exhaust camshaft sprocket, intake camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Left timing chain markings and installation: (D) exhaust camshaft sprocket (C) intake camshaft sprocket-3.8L Engine
    8. Install the left timing chain tensioner arm and torque the retaining bolts 14-16 ft. lbs.
    9. Install the left timing chain tensioner and torque the retaining bolts 7-9 ft. lbs.
    10. Install the left cam to cam guide and torque the retaining bolts 7-9 ft. lbs.
    11. Install the crankshaft sprocket, oil pump and right camshaft drive.
    12. Install the oil pump chain and oil pump sprocket. Torque the retaining bolt to 14-16 ft. lbs.
    13. Install the right timing chain guide. Torque the retaining bolts to 14-18 ft. lbs.
    14. Install the right timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, intake camshaft sprocket, exhaust camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Right timing chain markings and installation: (C) exhaust camshaft sprocket (B) intake camshaft sprocket-3.8L Engine
    15. Install the right timing chain tensioner arm. Torque the retaining bolts to 14-17 ft. lbs.
    16. Install the right timing chain auto tensioner. Torque the retaining bolts to 7-9 ft. lbs.
    17. Install the right cam to cam guide and torque the retaining bolts to 7-9 ft. lbs.
    18. Install the oil pump chain guide. Torque the retaining bolts to 7-9 ft. lbs.
    19. Install the oil pump tensioner assembly. Torque the retaining bolts to 7-9 ft. lbs.
    20. Pull out the pins on both the left and right hydraulic tensioners. Install the oil pump chain cover.
    21. Rotate the crankshaft two revolutions in the clockwise direction. Confirm the timing mark. Be sure to rotate the crankshaft in the clockwise direction.
    22. Apply sealant on the chain cover and on the cylinder head, cylinder block, and lower oil pan. Be sure these parts are free of engine oil and dirt.
      NOTE Before assembling the timing chain cover, the liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Sealant application (1 inch bead width)-3.8L Engine
    23. Apply sealant on the chain cover.
      NOTE The liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Timing cover sealant application-3.8L Engine
    24. Install a new gasket to the timing case cover.
      NOTE It is important that the dowel pins on the cylinder block and holes on the timing chain cover should be used as a reference in order to assemble the timing chain cover in the correct position.
      Fig. Timing cover gasket installation (A) gaskets-3.8L Engine
    25. Install the timing chain cover. Torque the retaining bolts in the proper sequence and to specification. The engine should not be started for at least thirty minutes after timing chain cover assembly.
      Fig. Timing cover bolt torque sequence and specification-3.8L Engine
    26. Install the timing case cover oil seal.
    27. Continue the installation in the reverse order of the removal procedure.
Timing chain 96 maxima broke
Check your owner's manual for the recommended mileage for replacing your timing chain. Replacement for a Nissan Maxima is 60,000 miles.2 Locate the timing chain. Replace it if the automatic chain adjuster (also known as the tensioner) is damaged or worn.3 Release the pressure in the fuel system, drain the cooling system and disengage the negative battery cable. 4 Undo the upper radiator hose, engine drive belts, power steering pulley and pump with bracket, air duct, passenger front wheel and engine side and undercovers, front exhaust pipe, cylinder head front mounting bracket and head cover, rocker cover, distributor and distributor cap and spark plugs.5 Take off the intake manifold support and move the No. 1 piston at "Top Dead Center" (TDC) of the compression stroke.6 Disconnect the cylinder head front cover, water pump pulley, thermostat housing, upper and lower tensioner and slack side timing chain guide, idler sprocket bolt, camshaft sprocket bolts, sprockets, mounting caps and camshafts. 7 Disengage the cylinder head with the manifolds, idler sprocket shaft, upper timing chain, center crossmember, oil pan and strainer assembly, crankshaft pulley, engine front mount and bracket and the front timing cover. Remove the oil seal and unfasten the timing chain cover, idler and crankshaft sprockets and the oil pump drive spacer. 8 Unfasten the timing chain guide. install Your Timing Chain 1 Grease the oil seal lip with engine oil and place it in the front cover. Verify that the No. 1 piston is at "Top Dead Center" (TDC) of the compression stroke. 2 Reconnect the crankshaft sprocket (marks should point toward the engine's front), oil pump drive spacer and timing chain guide and the lower timing chain. Line up all mating marks.3 Hook up the crankshaft sprocket and pulley, lower timing chain, front cover assembly, engine mount and front mounting bracket, oil strainer and pan assembly and center crossmember.4 Reattach the upper timing chain, idler sprocket (to the back side), cylinder head assembly, idler sprocket bolt and exhaust and intake camshafts. Place the intake camshaft knock pin at 9 o'clock and the exhaust pin at noon. Connect the camshaft bearing caps and distributor brackets and secure all mounting bolts.5 Eliminate any old material from the pan and cylinder block mounting surfaces. Rub on a 3.5 to 4.5mm bead of liquid gasket over the oil pan and cylinder block.6 Attach the upper timing chain to the idler sprockets and secure the cylinder head bolts.7 Refill the cooling system. Hook up the negative battery cable and any other disconnected items. Start the engine and look for leaks.
I would like to have a diagram of the timing comfiguration of a 2002 dodge intrepid 2.7 .....i am very interested in the timining marks for the camshafts
Hi, this engine uses plated links in the chain to match marks on the gears. See figure and installation procedure below. Let me know if you have any questions and thanks for using FixYa.
    1. Install the timing chain by performing the following procedure:
    1. Verify that the crankshaft sprocket timing mark is aligned with the mark on the oil pump housing.
    2. Place the left side primary timing chain sprocket onto the chain, while aligning the timing mark on the sprocket to the 2 plated links on the chain.
    3. Lower the chain with the left sprocket through the left cylinder head opening.
    4. Loosely position the left camshaft sprocket over the camshaft hub.
    5. Align the plated link to the crankshaft sprocket timing mark.
    6. Position the timing chain around the water pump drive sprocket.
    7. Align the right camshaft sprocket timing mark to the plated link on the timing chain and loosely position the sprocket over the camshaft hub.
    8. Verify that all the plated links are aligned to their proper timing marks.
    1. Install the left lower timing chain guide and tensioner. Torque the bolts to 21 ft. lbs. (28 Nm).
      NOTE Inspect the timing chain guide access plug O-rings before installing. Replace damaged O-rings as necessary.
    2. Install the timing chain guide access plug to the left cylinder head and torque to 15 ft. lbs. (20 Nm).
      NOTE To reset the timing chain tensioner, oil will first need to be purged from the tensioner.
    1. Purge oil from the timing chain tensioner using the following procedure:
    1. Remove the tensioner from the tensioner housing.
    2. Place the check ball end of the tensioner into the shallow end of the Tensioner Resetting Special tool 8186.
    3. Using hand pressure, slowly depress the tensioner until oil is purged from the cylinder.
    4. Reinstall the tensioner into the tensioner housing.
    1. Reset the timing chain tensioner using the following procedure:
    1. Position the cylinder plunger into the deeper side of the Tensioner Resetting special tool 8186. Apply a downward force until the tensioner is reset.
    WARNING
    Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    1. Install the chain tensioner into the right cylinder head.
    2. At the right cylinder head, insert a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    3. Turn the left camshaft by inserting a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    4. If necessary, rotate the engine slightly clockwise to remove any slack in the timing chain.
    5. To arm the timing chain tensioner: Use a flat-bladed prytool to gently pry the tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner extends.
    6. Inspect and replace the timing chain cover gasket and oil seal.
    7. Apply a 1 / 8 in. (3mm) bead of sealer at the parting line of the oil pan and engine block.
      NOTE When installing the timing cover, guide the seal over the crankshaft to prevent damage to the seal-s lip.
    Install or connect the following:
    Timing cover and gasket and torque the M10 bolts to 40 ft. lbs. (54 Nm) and the M6 bolts to 105 inch lbs. (12 Nm)
    Accessory drive belt tensioner pulley
    Power steering pump
    Crankshaft damper
    Crankshaft center bolt and torque the bolt to 125 ft. lbs. (170 Nm) using tool 8191
    Fan module and electrical wiring harness
    Upper radiator crossmember
    1helpful
    2answers
    2helpful
    2answers
    Timing on 4.7 help
    INSTALLATION
    1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin (Resetting Secondary Chain Tensioners).
    2. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
    3. Install right side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.). NOTE: The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
    4. Install the left side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
    5. Install left side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.).
    6. Install the right side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.).
    7. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8515 to hold chains in place for installation (Installing Secondary Timing Chains on Idler Sprocket).
    8. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket (Timing Chain System).
    9. Lubricate idler shaft and bushings with clean engine oil.
    10. Install all chains, crankshaft sprocket, and idler sprocket as an assembly (Installing Idler Gear, Primary and Secondary Timing Chains). After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or the equivalent, This will maintain tension on chains to aid in installation. NOTE: It will be necessary to slightly rotate camshafts for sprocket installation.
    11. Align left camshaft sprocket “L” dot to plated link on chain.
    12. Align right camshaft sprocket “R” dot to plated link on chain. CAUTION: Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over-torque of bolt resulting in bolt failure.
    13. Remove Special Tool 8515, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
    14. Verify that all plated links are aligned with the marks on all sprockets and the “V8” marks on camshaft sprockets are at the 12 o'clock position (Timing Chain System). CAUTION: Ensure the plate between the left secondary chain tensioner and block is correctly installed.
    15. Install both secondary chain tensioners. Tighten bolts to 28 N·m (250 in. lbs.). NOTE: Left and right secondary chain tensioners are not common.
    16. Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 34 N·m (25 ft. lbs.).
    17. Remove all locking pins (3) from tensioners. CAUTION: After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
    18. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left (Tightening Left Side Camshaft Sprocket Bolt) and right (Tightening Right Side Camshaft Sprocket Bolt). camshaft sprocket bolts to 122 N·m (90 ft. lbs.).
    19. Rotate engine two full revolutions. Verify timing marks are at the follow locations:
    20. Lubricate all three chains with engine oil.
    21. After installing all chains, it is recommended that the idler gear end play be checked (Measuring Idler Gear End Play). The end play must be within 0.10–0.25 mm (0.004–0.010 in.). If not within specification, the idler gear must be replaced.
    22. Install timing chain cover (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT / CHAIN COVER(S) - INSTALLATION) and crankshaft damper (Refer to 9 - ENGINE/ENGINE BLOCK/VIBRATION DAMPER - INSTALLATION).
    23. Install cylinder head covers (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION). NOTE: Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
    24. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 81 N·m (60 ft. lbs.) (Cylinder Head Access Plug Location).
    25. Install the oil fill housing.
    26. Install access plug in left cylinder head (Cylinder Head Access Plug Location).
    27. Install power steering pump (Refer to 19 - STEERING/PUMP - INSTALLATION).
    28. Install radiator fan shroud.
    29. Fill cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE).
    30. Connect negative cable to battery.
    4helpful
    2answers
    Engine knock noise on cold startup
    these 3.3l engines are equipped with timing chains. if vehicle has prolonged down time, typically more than 4 hours, vehicle makes a chatter until the timing chain tensioners put tension on the chain. you will need them replaced.
    Top Toyota Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    ROBERT GARCIA
    ROBERT GARCIA
    Are you a Toyota Expert? Answer questions, earn points and help others
