Controladoras IDE ATA/ATAPI - Computers & Internet
    Guru:
  • 433 Answers
Re-install windows if you mean softwere with controladorrs
Posted on Mar 27, 2011
Tip
Turn Direct Memory Access (DMA) on or off You must be logged on as an...
You must be logged on as an administrator to perform these steps.
is usually turned on by default for devices such as CD or DVD drives that support DMA. However, you might need to turn on DMA manually if the device was improperly installed or if a system error occurred.
  1. Click to open Device Manager. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Double-click IDE ATA/ATAPI controllers.
  3. Under IDE ATA/ATAPI controllers, for each item that has the word Channel as part of its label, right-click the item, and then click Properties.
  4. Click the Advanced Settings tab. Under Device Properties, select or clear the Enable DMA check box, and then click OK.
on Dec 14, 2010 | Computers & Internet
My e drive has disappeared from computer
Try one of these:
1. http://support.microsoft.com/kb/314060
or...
2. http://aumha.org/downloads/cdgone.zip
or...
3. Go to Device Manager, click a "+" sign next to IDE ATA/ATAPI Controllers.
You'll see two items:
- ATA Channel0 (or Primary Channel)
- ATA Channel1 (or Secondary Channel)
Right click on each of them, and click Uninstal. Confirm.
Restart Windows. They'll be automatically reinstalled.
Mar 16, 2010 | Acer Aspire 5100 Notebook
Philips dvd+rw sdvd8441 dont burn
That should be set to DMA: On.
Go to Start > Run and type in devmgmt.msc
Double-click IDE ATA/ATAPI Controllers > Double-click Secondary IDE Channel > Advanced Settings
Set Transfer Mode to DMA if avaliable
Jan 19, 2010 | Gateway MX6214 Notebook
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
No sata l type on my motherboard
the only way i know is to buy a convertor like the 1 from the link
http://www.cooldrives.com/serial-ata---ata-atapi-ide-interface-adapter.html
might be easier to just swap the drive you have if youve just bought it or buy a new ide drive
Mar 13, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
MB Foxconn 661M03-G (s. 478) problems with IDE/ATAPI controllers
Hello uxmal,
The Drivers of 661M03-G
On-Board VGA Drivers: Click Here
AGP Drivers: Click Here
On-Board Audio Drivers: Click Here
BIOS File: Click Here
Thank you for using FixYa.
Mar 08, 2009 | Foxconn 661M03-G-6EL Motherboard
Still needed solution of problem
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Feb 09, 2009 | Compaq Presario Notebook
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Computers & Internet Logo
David Payne
David Payne
