Car Audio & Video Logo
Posted on Mar 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my brother in law installed my kenwood kdc-w4044u stereo into my 1999 vw golf.... works ok but when i remove the keys the memory goes... can you help
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Kenwood Master 2,226 Answers
  • Posted on Mar 28, 2011
kenw392
Kenwood Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
474366
Points
4986
The yellow wire needs to go to a constant power source. the yellow wire controls the memory and needs to have power going to it when the key is turned off.
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Need to remove kenwood kdc 315s stereo to replace my heater unit on 95 civic, how do you remove stereo?
If you remove the outer trim ring look on each side toward center edge you will notice 2 slots one on each side of unit. You will need a set of Kenwood keys to remove the unit from the cage. If you do not have the keys for the unit you will need to take it to a stereo install/repair shop and have them to pull the unit for you.
Hope this helps!
1helpful
I need to know how to install an aftermarket stereo in my 1995 vw golf....
go to your local halfords or the likes and you will need to get a wiring harness designed specifically for your car.you will need to tell them what kind of aftermarket stereo you have as the harnesses are all different.
I need unlock code for my kdc-mp2035 kenwood stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Car stereo not working
somthings wrong with your ignition wire run your stereos power on a toogle switch
1helpful
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
4answers
Stereo code for vw golf
try somebody with a vag.com near you they may be able too get code out for you..
2helpful
Kenwood KDC-MP832U display not working
I had this problem! It was the Cars Battery. Kenwoods unit's fade or go completely blank when there is little power to power the stereo. Try charging your battery or grabing a new one from a scrappy! I was all over the net looking for help but finally sorted it!
P.S. My younger brother had to do the exact thing and it worked for him as well!!!
62helpful
9answers
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
