I've got a document to print and when I click print it tells me (in the jobs queue) it is idle. This has only happened within the last few weeks. How can this be solved?
    Guru:
  • 89 Answers
Power Cycle the printer sometimes resolved a problem like this.
Go to printer properties
right click and choose see whats printing for vista and win7 and click open for windows xp
pop up window will open then click on printer and cancel all documents
this will clean documents stuck on queue
go to start and click search for win7 and vista or click run for win xp
type services.msc
pop up window will open then look for print spooler
click restart on the spooler then it will restart only the print spooler
try printing again
Issue
The solutions in this document address the issue of print jobs getting stuck in the print queue
A log of print jobs waiting to print
. The following symptoms might also accompany this issue, and this document does address these other symptoms:
Printer won't print
Printer is Offline
No response from product
Check the print driver and the port
If you ever installed more than one HP product on the computer, the product might not be the default printer, or the wrong print driver might have been configured. Follow these steps to check the print driver configuration.
1.
On the Windows taskbar, click Start ( ), click Control Panel , and then double-click Printers and Faxes . The Printers and Faxes folder opens.
2.
Look for a black checkmark ( ) next to the product icon. This checkmark indicates which product is the default printer.
Figure 14: Example of default printer icon
Illustration of the default printer icon in Windows XP
If the wrong product is the default , right-click the icon for the correct product, and then click Set as Default Printer .
If the correct product is the default , continue to the next step.
3.
Right-click the icon for your product ( ), and then click Properties . The printer Properties window opens.
4.
Click the Ports tab.
5.
Look for your product under the Description column, and then view the Ports column to the left.
6.
Select your connection type to determine which port you should use
Posted on Mar 27, 2011
  • mdavis121 Apr 10, 2011
    how do you know what port to use?
  • christian velasco
    christian velasco Apr 10, 2011
    if it is usb there should be USB0001
    If it is wireless ther should be an IP address. Example: 192.168.1.12
    Hope it helps you fix the issue.
    Regards
    Christian
What to do if after canceling the printing in queue document its status is still showing deleting ?
Give it a few minutes. Sometimes it takes awhile to delete the document.
If that fails, turn off the printer, wait a minute, then turn it back on. The document should be deleted.
Jun 29, 2015 | Office Equipment & Supplies
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
Printer was working, but is not now. All cables are hooked up properly and have been disconnected and reconnected. I have several documents in the memory to be printed, but the printer will not respond. ...
Here are four things you can try; may not have to perfom all:
Check to see if your printer is off-Line
1.Open the Printers, Printer and Faxes, or Device and Printers folder.
To do this:
Windows XP users; Click on Start > Settings > Printers an Faxes or Start > Control Panel > Printers and Faxes.
Windows Vista users; Click on Start > Control Panel > Hardware and Sound > Printers.
Windows 7 users; Click on Start > Device and Printers.
2.Right-click on the printer object (icon), and select Use Printer Online.
3.Microsoft Windows 7 users will double-click on icon, select printer and then de-select Use Printer Offline.
Printer Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation:This is typically an end user error. Hint: Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do:
•Double-click on the print queue icon to open the print queue.
•Click on Printer in the upper left-hand corner of the menu bar.
•Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Delete print jobs from the print queue
Access the print queue.
Delete all print jobs
• Click on Printer in the toolbar and then click on Cancel All Documents,
or
• Right-click in the print queue and select Cancel All Documents from the pop-up menu.
You can also delete individual print jobs
1.Highlight the individual job in the print queue by clicking on it.
2.Right-click on the highlighted job and select Cancel from the pop-up menu.
IMPORTANT! If a job is stuck in the print queue and cannot be deleted or canceled using the above steps, there may be an issue with the printer spooler that controls the printing options in Windows. If you observe this symptom, it may be necessary to stop and restart the print spooler; then retrun to delete print jobs.
How to Stop and Restart the Print Spooler
Problem:
Unable to cancel print jobs; Unable to print; Print queue is unresponsive; Locked print queue; Unable to print; Cannot cancel print job; Printer driver not responding
Solution:
The print spooler controls print options within Windows. A problem with the print spooler can affect printer driver performance and Windows print queue responsiveness. Stop and Start the print spooler to see if observed symptoms subside or remain.
Method 1: Using Administrative Tools
Step Action
1 Click on the Windows logo start button.
2 Click on Control Panel on the right-hand side of the start menu contents.
3 Click on Maintenance.
4 Click on Administrative Tools.
5 Click on Services. NOTE: You may have to provide an administrator profile and password.
6 Scroll through the list and look for Print Spooler.
7
The following two options are available to stop and start the print spooler:
•Click once on Print Spooler to highlight it, and then click on the Stop or Start links in the right-hand window pane,
or
•Double-click on Print Spooler, and click on the Stop button followed by the Start button.
8 Observe the status column in the Services window to verify that the print spooler is stopped or started as applicable.
Trust this helps to resolve your problem. Please vote.
Dec 29, 2010 | Lexmark X5495 Printer
How do I get the printer to print
Click on the printer icon at the bottom right of the screen. It should bring you to the print queue.
Make sure that the print queue has been released. Sometimes the queue will be in a "Hold" status.
You can also release each print job by clicking on the job and directing the queue to send the job to the printer.
Don
May 20, 2009 | Lexmark X6100 Flatbed Scanner
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Goodluck,
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Unable to stop printer from printing documents
The actual folder in Windows where spooled documents are stored just before printing is: C:\WINDOWS\System32\spool\PRINTERS. I?ve never had print jobs hanging around after the print queue has been deleted but if you clear out anything in this folder that should take care of it. Let us know how things work out and please don?t forget to rate this posting.
Mar 17, 2007 | Samsung ML 2010 Laser Printer
94 people viewed this question
k24674
jasbo
jasbo
