I have easycad powerglide 413 g golf buggy with 1228 curtic controller looking for forward and reverse speed control pot easycad not replying to e mail or answer phone
maklean
  • 1665 Answers
SOURCE: Cannot send, reply or forward my Yahoo e-mail
In microsoft outlook, clik on Tools> E-mail accounts>View or change existing e-mail accounts>change > correct outgoing mail server (SMTP) settings and press Test Account Settings.
If you receive a Task error message: ( X Send test e-mail message "Failed" ) perhaps you have been disconnected by your e-mail provider.
Posted on Dec 26, 2007
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
  • 25 Answers
SOURCE: casa blanca fan motor speed control
www.casablancafanco.com
Posted on Jan 19, 2009
SOURCE: Remote Control for a Panasonic DMR-EH55
You can get one at Partstore.com
Posted on May 29, 2009
protek480
  • 1723 Answers
SOURCE: Club Cart Golf Cart Reverse only
You don't have it connected right. The DC motor is 'polarity reversed' to change direction. That's what the controller does is reverse the polarity to the motor to change direction. If the motor is still working in reverse, then the controller is 'probably' okay. Recheck the connections you made.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
Ezgo 36 volt buggy i have 2 one in good running order other one not going now solenoid not clicking have swwapped solenoid and controller to good running cart and it works problem cart still problem
Hope it's fixed by now. If the solenoid is not clicking then one of your switches is bad or wiring. Check the key switch, forward/ reverse micro switch, and the switch in the floorboard that is connected to the gas pedal.
Apr 19, 2017 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Minn kota e drive
Need the model #. During the mean time(back in the buggy farm) trace the wiring & check the control switch operation including the connections. Trial & error-swap the polarity on the main power feed to motor control & check ops. Motor runs forward, motor OK.
May 21, 2014 | Boating
How to change a travelmate 3 to left handed control
i think you mean forward using left hand, reverse using right hand, if so there should be 1 red and 1 black wire from the motor going to the motor controller if you switch these wires then your throttle should work the way you want but unless there is a speed control pot on the throttle enclosure you may also now run faster in reverse than forward
Mar 29, 2014 | Amigo TRAVELMATE Mobility Scooter ()
My exceed doesnt go into reverse
your ESC (speed controller needs resetting
Nov 14, 2012 | Exceed-RC 1/10 Scale Exceed-Rc SunFire...
Hi my scooter will drive in reverse on its own at all kinds of speeds if u leave the key on and is slow in forward only it will only stop in reverse if you turn of key or disconnect the forward or reverse...
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
May 02, 2011 | Health & Beauty
My new buggy does not run.Battery is ok,the fan on the power control is ok ,steering from ternsmitter is working,but vehicle does not move.Thanks in advance.Costas from Athens.
you either need to calibrate your hand controller to your esc or if your hand controller batteries are flat you will have no forward reverse
Jan 08, 2011 | Kyosho Inferno Ve Rtr 18 Electric 4wd...
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
