Question about Canon MV530i Mini DV Digital Camcorder
What type of av cable is compatible with a Canon MV530i camcorder?
  • 3 Answers
The AV lead for your type of camera is a triple-segment mini-jack, which leads to yellow, red and white phono plugs.
Yellow is for composite video, white is for the left stereo and red is for the right stereo channel.
Posted on Mar 07, 2012
3 Suggested Answers
SOURCE: how to record from a VCR onto a canon mv530i
OK get a set of cord that can be used, on the back of most VCR's there is RCA Sockets for Video & Audio out... generally Red & White & Yellow these go to the corresponding inputs on the camera's Video & Audio inputs, OR Correct adapter. The camera must have the correct A/V INPUT selected. Then start the VCR to "Play" the tape, and set the Camera to "Record" this will/should then record the output from the VCR to the memory in the Camera.
Posted on Aug 21, 2007
  • 10 Answers
SOURCE: Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Posted on Mar 05, 2009
Sd card 4gb error
Your new 4GB card is actually an SDHC card. The MV530i works with SD cards, 2GB and smaller. It will not work with SDHC cards.
Jun 08, 2013 | Canon MV530i Mini DV Digital Camcorder
Tip
Drivers canon mv530i winxp
i need canon mv530i drivers winxp can you help me..........thanks
on Mar 18, 2008 | Canon MV530i Mini DV Digital Camcorder
New SD card does not work
The MV530i works with SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
How to transfer from the tape to computer to burn a dvd
To transfer your canon data in tape, you need to install driver of canon mini dv in your computer. Then paired your canon with computer trough usb to make data transferring. To burn a dvd disc you need to install software for dvd burner like Nero S in your computer to edit your AV and burn into DVD disc. Make sure your computer have DVD R/W to do so.
Regards. Jay
Dec 26, 2010 | Canon MV530i Mini DV Digital Camcorder
Need a manual for the Canon MV530i
To download the instruction manual for required product, please click the respective link below:
Canon MV530i Manual
Canon MV650i Manual (Product category selected)
Please rate the solution.... :)
Thank you
Dec 02, 2008 | Canon MV650i Mini DV Digital Camcorder
Export movie from an older TRV68 to computer
I purchased a canon elura 100. The 100 has a AV -> DV converter. This allow you to tunnel your Sony via a 3.5mm 4-pole mini AV to mini AV camcorder A/V cable to your computer.
Sony (via AV out) -> (AV) Canon -> PC/Mac (DV) via fire wire cable
Feb 12, 2008 | Sony Handycam CCD-TRV68 Camcorder
MV530i Mini DV
The mechanical part of the camera is gone. You better replace the camera with a new one.
Dec 06, 2007 | Canon MV530i Mini DV Digital Camcorder
Connecting to computer
You have installed the software on the PC from the disk, correct?
To check go to start>All programs>look for the software in there.Is it in there?
Oct 21, 2007 | Canon MV530i Mini DV Digital Camcorder
How to record from a VCR onto a canon mv530i
Aug 21, 2007 | Canon MV530i Mini DV Digital Camcorder
Canon MV530i Mini DV Digital Camcorder Logo
98 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
