Question about Air Intake & Fuel Delivery for Volkswagen Golf R
Hi. My 1999 1.6 vw golf is loosing power and is very jerky. I have a feling it is to do with the air intake. How do i fix this?
    Scholar:
  • 113 Answers
If you sure about problem on intake. Take your intake booth maf and air filter complete box out of the vehicle. inspect and clean your intake booth check if any posible air leak on it, check your maf sensor (use only maf sensor cleaner another cleaners may damage your sensor) if no any leak go to air filter box make sure air filter is in good and clean , on bottom piece of filter box there is another filter screen from the air inlet from out side make sure it is clean (get clug a lot from out side dirts ) if you did not find any cracks thats causes leak any air intake completly clean and still have problem you may go another step . good luck
Posted on Mar 27, 2011
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How to replace gasskets on a vw golf 1
Head Gasket failure. Go online to mm, Amazon and search for a used Bentley Manual for your car. I have three VW's so trust me on this one.
Mar 26, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Adjust shift linkage on a golf 4 speed gearbox
From the images I'm finding of it online it appears the easiest way to adjust it would be to take it loose. put the tyranny in first, as well as the shifter. Then adjust the linkage to fit, being careful not to move the shifter as you do it. do so for both linkages and run through the gears with the engine off and clutch dis-engaged to ensure you feel it hitting the gears as you move through them.
Make sure the linkages and everything does not have play it in or it will not be able to be adjusted. worn parts will have to be replaced.
GmsCool
Mar 12, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Need help 95 golf!!!
I'd replace the crank speed sensor .. you can get them on fleebay for 20$.. kind of a PITA to see but it's right under the oil filter. I have a 96 golf gl and have fixed just about every GD thing on the car, but i love it so i will keep fixing it.. This took care of the problem for me
- Joe
Feb 27, 2013 | 1995 Volkswagen Golf
Vw golf chico 1.4 2004 brake pedal faulty
golf chico 1.4 starts to jibb and loosing power when i excellerate. any advice???
Feb 25, 2010 | 2004 Volkswagen Golf
Vw tdi turbo dying
check the rubber pipes are not collapsing ,they run from the air filter to the turbo if they appear ok then replace the turbo
Jun 16, 2009 | 1999 Volkswagen Golf
Vw golf est dashboard coil or spring shaped
thats the heater coil symbol for the diesel engines.
does it stay solid at beginning as normal?
if the car drives normal, then maybe its just a loose connection/wire somewhere
Mar 09, 2009 | 1999 Volkswagen Golf
VW Golf 1 - Idle problem
exactly same problem on mine m8.....a good service fixed the problem.....new air filter, oil, oil filter, spark plugs, distributor cap, rotor. when i took the air filter out and looked at the air flo pipes they were clogged up with white gunk....means the engine wasnt breathing rite. i cleaned it with break cleaning fluid. i dnt no which 1 of these solved the problem....but my guess wud be the pipes
Feb 25, 2009 | 1997 Volkswagen Golf
Air Intake & Fuel Delivery for Volkswagen Golf R Logo
145 people viewed this question
Top Volkswagen Vehicle Parts & Accessories Experts
dadr
Level 1 Expert
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
