Question about Rapid Wall Bench or Bracket Mount - 3/8" Air Hose Reel
I have just aquired my deceased sistershozelock reel .I have mounted it correctly onthe wall and run a hose from the tap to connecter just inside the reel on the right hand side but no water comes out the main hose. any ideas.
    Sergeant:
  • 259 Answers
It sounds like there is a obstruction in the line. disconnect the connection from the reel to the hose shutoff and blow the line out with compressed air.
Posted on Mar 27, 2011
Do i have to turn water off to disconnect a washing machine
normal practice plumbing is to connect the machine hoses to the wall taps
unless you have something different ,turn the taps off at the wall and unscrew the hoses
if your practice is to leave the wall taps on all the time ,when you start to undo the hoses there may a bit of water squirt out as that will be the pressure still in the hoses
Apr 22, 2015 | Washing Machines
When I set machine on cold wash the water is hot and vice versa. How can I fix this?
reverse the water supply hoses either on the wall or on the machine. be sure to turn off water valves first. or just wash hots in cold etc. :-)
Apr 05, 2015 | Fisher and Paykel Washing Machines
Inlet valve rotates with hose
when the hose is connected it will hold it from going around
Jan 19, 2014 | Goodyear 1/2" X 50 RETRACTABLE AIR HOSE...
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
Want to remove present dishwasher for replacement with a new one. How do you do it.
Most dishwashers are housed in a cabinet next to your kitchen sink.
Not knowing how exactly your machine is set up I will just advise you on common setup features and removal.
First open the doors to kitchen cabinet under the sink. If you see two hoses connected under the sink, they most likely are from your dishwasher. One is an inlet hose which would be connected to a water tap. The other would be a drain hose which would be connected via a clamp to the drain under your sink.
Turn off water tap to remove inlet hose. Unscrew or undo the clamp fixing your drain hose to drain pipe. Note when you remove the drain hose the hole to the drain pipe is exposed. You need to block this off as it will leak water when ever the sink is running. I normally get a plastic bag and twist it inside the hole and tape it off.
Next you need to locate the power cord and plug for the dishwasher. This is normally under the sink cabinet as well. However, check either side of the dishwasher. Sometimes they are behind the dishwasher.
Once you have disconnected the hoses, open dishwasher door. Look on the inside walls of the dishwasher. Some models are screwed into the wall of the cabinet so you need to unscrew machine. The screws go in either from the side walls or from the inside roof of dishwaser to your benchtop.
You need to also remove the kitchen kickboard if one has been installed infront of the dishwasher.
When machine is free open the diswasher door and grab either side of door and gently pull machine out. Have someone help you feed the hoses through as you pull out.
If the machine does not easily pull out check again for hidden anchor screws around the edges of the machine or even clamps which fix the hoses to the cabinet.
If you have issues pulling it out see if you can take some pictures and I will help you.
ash
Sep 11, 2011 | Dishwashers
I have the suncast model of hose reel that u have to manually wind. i tried to put a new hose in but it seems i loaded it wrong. When i went to use it the hose that hangs out that hooks to another would...
The hose on the side that connects to the water supply is not the same hose that goes inside.
The side hose connects to the faucet and the fitting on the hose reel is not supposed to rotate.
The hose that the homeowner installs connects to the adapter on the center of the reel and this goes around when the spool is turning. Beyond that, I don't really understand the question. Hopefully this will give you some information that you can use and then post back.
Gary
Apr 17, 2011 | Garden
I am getting the error code "HC" since we replaced a hot water heater. What does it mean? How might I correct this? Whirlpool Cabrio
There is most likely debris from the plumbing repair / install of the hot water heater that has migrated into the inlet screens of the washing machine. Turn off the water supply. Remove the water hoses from the water inlet valve and then use a thin bnladed kinfe to coax the inlet screens out of the inlet water valve body. Wash then under slow running water by gently rubbing your fingers over them until they are clean. Hod the screens up to a light source to make sure you have them totally clean. Reinstall the CLEANED screens and connect the water. This should correct the HC code.
If not there is one more series of steps to do:
- Water supply OFF
- Remove both hoses at water valve inlet
- Remove the inlet screens
- Reconnect BOTH hoses to the inlet water valve.
- Remove ONE hose from the Wall water supply and place it in a bucket TURN ON THE REMAINING HOSE connected to the wall.
- Start a WARM fill cycle and tap the water valve hose connections with the HANDLE of a hammer or the head of a very large screw driver while the unit is filling. (15 seconds)
- Stop fill cycle and turn off water to connected hose
- Reconnect removed hose to the wall connection.
- Reverse hose positons and place 2nd hose in the bucket. Thern ON the hose still connected to the wall.
- Start a WARM FILL cycle.
- Gently tap the water valve hose connections 15 seconds
- STOP Fill
- reinstall inlet screens and connect all hoses.
- test fill cycle and return to normal service
Thanks for choosing FixYa,
I am Kelly
Mar 16, 2011 | Washing Machines
Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Dec 17, 2010 | Washing Machines
Bought a Hoselock Hose Reel today and cant figure
You need to purchase a Hoselock tap connector. There are two basic types, one has a thread that screws on to a theaded tap and the other type is a compession fitting that can be secured to most other taps.
The full range of connectors can be found on their website
http://www.hozelock.com/watering/hose-fittings/connect-to-tap.html
Mar 16, 2010 | Hozelock Garden
Washing machine keeps filling water doesnt shut off? whats wrong with it?
Hi and welcome to Fixya. The water vavle has a piece of foreign debris stcuk onthe internal diaphram. You can possibly clear this by removing one of the hoses at the wall connection. You will have to turn off both hoses at the wall initally. Place the removed hose into a bucket of water . Then turn on the one that is still connected to the wall. Place you machine on WARM wash and start filling the machine. GENTLY use the HANDLE of a screwdriver or hammer and tap the water valve at the hose connection. Let the water run for about 1 minute. Now stop the filling. Reverse on the wall hose connections and repeat the procedure above for the other hose.
If the problem does not clear you will have to change the water valve or take it apart and clean the diaphram.
Jan 24, 2010 | Kenmore 22422 Top Load Washer
Rapid Wall Bench or Bracket Mount - 3/8" Air Hose Reel Logo
67 people viewed this question
Top Rapid Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Rapid Air Tool and Compressor Expert? Answer questions, earn points and help others
