Question about Square Enix Brainlord for Super Nintendo
Stuck in flood gate room. whats the key to the contrl pad?
1996. How do I open locked, stuck tail gate?
You can take the panel off on the inside of the tail gate, and open it by manually pulling on the linkage rods at the same time.
Dec 06, 2015 | Isuzu Rodeo Cars & Trucks
I have a 2002 trailblazer ext, so the other day I was about to jump in my car when pressing the keyless entry button didn't work?!... So I used the key opened my car pushed the u lock bottom on the inside...
Try changing the battery in your key pad, the signal could be weak therefore not working properly, also could be the pad itself may require a new one to be programmed, also I have experienced some same problems and it turned out to be the "Convenience Control Module" of my vehicle and not the key pad at all, hope this helps!
Nov 29, 2013 | Cars & Trucks
I have a nissan mistral van SUV & Off Road type 4WD. Th e is key is stuck on the driver's door and I can't get out. I try to open the door and the key is still stuck. Please how can I remove it from...
get a bottle of spray lube that has the little red spray tube and flood the lock along the key with lube,, turn key right to left and wiggle up and down,, flood the lock again and push in and pull out on the key a few times and turn key right and left and flood the lock again,, push in and pull out. if this does not remove the key then what has happened is you have a stuck,jammed or broken wafer in the lock and it is binding against the key. the best way to deal with this issue if the key does not come out is to call a locksmith and have him come out and fix the lock and remove the key.
if you do not want to call a locksmith and you are handy with tools -- you can pull the door panel off and remove the door lock and try and manipulate the wafers and get it to release the key. with the lock in hand use a small pin to try and move the wafers away from the key.
c...
Jan 21, 2011 | Nissan Pathfinder Cars & Trucks
I have an KDS Product # XF-76 (product series DZ 777NS) and it keeps giving me the screen to change the contrast etc. I go to exit but it keeps coming up every few minutes.
This is a contrl board problem this will need to be repaired, Sounds lie one of the button pads on the control board has malfuctioned or is stuck pressed in you might want to check all your buttons make sure there not pressing down or stuck. Hope this helps I am sure it will need a controler board if it does not, this does not cost but $35 for the part to fix.
It wass my pleasure answerign your question please make sure you leave a rating before you leave, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 11, 2010 | Computers & Internet
Gets stuck in defrost and floods the floor - happens about once every 2 months - sticky relay ??
ir ur lick a raly ,but prob not, , deforst dil has pronly gona bad and needs to be replaed, it on a timer in ur contrl dial
May 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
2006 jetta 2.0 t with a coode p0299. what needs to be replaced...help please
this code is in reference to a turbo fault code that comes up either with a weak turbo or internally leaking turbo / dragging turbo impeller /pintal shaft,
could also refer to a turbo waste gate vacumn contrl issue
Jan 21, 2010 | 2006 Volkswagen Jetta
Our horizon dsx gate system suddenly lost power, no display and key pad is not working. What can I check to possibly fix this?
First of all check circuit breaker supplying the gate to see it has not tripped.
Also check power is coming out of the circuit breaker in case it is faulty.
You now know if supply is being sent to gate transformer.
Check supply is arriving at gate with mains tester. if so check low voltage side with small multimeter.ONLY DO THIS IF YOU ARE COMPETENT WITH ELECTRICS.If all power is reaching the pcb (printed circuit board) then a call out will be needed as the fault may be in the board itself.
here is a link to a brochere that may help.
http://www.sentexsystems.com/pdfdocs/6001037.pdf
Oct 12, 2009 | Home Security
1ST LEVEL,WHERE DO i FIND KEYS TO THE GARDEN
COURTYARD WITH PALM TREES AND TIGHTROPE: Enter cautiously, Larson waits in the next room, up on a balcony to the left. Let him have it with your pistols and he'll run off shortly. Pick up a small medipak in the alcove on the right. Then go through the doorway below where Larson was standing. First go left down the ramp to a room with boxes. Here you'll find a GARDEN KEY (shaped like a star) on one crate.
Return to the hallway and continue left to the top. Larson will shoot at Lara again from the other side of the gap. Again, plug him a few times to scare him off. Then tightrope walk across to the opposite balcony. Drop down and, if you like, use the switch to open a gate leading back to the FOUNTAIN COURTYARD. (NOTE: As before, you don't have to do this, but it could save you some backtracking.)
Head away from the gate toward a WIDER STREET WITH A GATED GARDEN off to the right. This is where you'll use the GARDEN KEY, but you need another one first. Go to the left end of the street and through the small, square doorway. Follow the hallway, picking up some revolver bullets in a small room on the left. Make a mental note of the LOCKED WOODEN GATE with the small room behind it. This is the location of the second secret. You'll come back for it later.
Continue upstairs. Be sure to pick up the REVOLVER on the landing. (You probably won't miss it because the camera focuses on it so you're unable to look at anything else.) At the top of the ramp, push open the blue double doors. Inside this SMALL ROOM WITH WINE BARRELS you'll find the LASER SIGHT on the floor to the left and a padlocked gate on the right. Shoot the padlock: either use the revolver equipped with the laser sight to target it (check your instruction booklet or see the section on 'using the laser sight' on the TR5 controls page), or face the lock squarely and shoot continuously with pistols while crouching. Lara should hit the lock on the way down. Behind the gate is the second GARDEN KEY. A colony of rats swarms out. Some of these will try to bite Lara, so if you've gotten everything, run away downstairs. Or, run out, jump the railing and wait for the bats to disperse before returning to collect the key.
May 26, 2009 | Eidos Interactive Tomb Raider: Chronicles...
Square Enix Brainlord for Super Nintendo  Logo
59 people viewed this question
Top Square Enix Video Game Consoles & Games Experts
James Wishart
Are you a Square Enix Video Game Console and Game Expert? Answer questions, earn points and help others
