Question about Packard Bell (181368) Motherboard
Want to know whats the maximum hard drive i can put in my pc it as a bv cuba ms-7301
  • 12 Answers
Generally, you can put 2 devices (hard drives or CD/DVD drives) per IDE chain and 1 device per SATA port. It appears there are 2 IDE chains and 2 SATA ports, so theoretically you could have 6 hard drives hooked up (assuming you don't use an optical drive). Four would need to be IDE, two SATA.
Posted on Mar 27, 2011
Maximum hard disk size for hp a1610n
Based on The Spec's of your System you have a 250gb Hard Drive however the Maximum size will be less then that due to formatting the drive so you can expect that to be like 10% less then 250gb (just a guess) plus a lot of computers come with a restore partition which is usually around 12gb assuming you leave it factory stock.... Your computer by default will set your Hard Drive to the Maximum size... now as far as how big you can install the sky is the Limit your computer is new enough it should except any size Hard Drive available at the store.
Oct 14, 2013 | HP Pavilion Computers & Internet
7301 manual
You would seem to be experiencing some dodgy RAM.
Sep 16, 2013 | MSI Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
I want an update for the BIOS on my computer. It is a Packard Bell iMedia 1569 with a Cuba MS-7301 version 1.0 baseboard. Can you help?
The best way to do it is to downlaod the bios available on your manufacturers website with the correct model no.
Save it on the computer.
Right click and then select run as a administarator.
Go through the proces.
restart the computer when you are done.
Sep 23, 2010 | Computers & Internet
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
Reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Aug 15, 2009 | MSI Computers & Internet
Cannot find hard drive while installing MS XP on a hp nc6220 laptop.
hi
It used to happen like this during the new installation.
goto BIOS setup and check that the HDD is correctely detected. check the size it reported. If its correct, give one more try. else the HDD firmware is corrupted and can be repaired.
thank you
Aug 15, 2008 | Microsoft Windows XP Professional for PC
Packard Bell (181368) Motherboard Logo
296 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
