Drum wont go around or spin its not the belt as its still on
  • 2,510 Answers
Try turning the drum by hand to see if it is not the bearings that have siezed, If the drum turns see if the belt is not too slack and is slipping. with the back removed and the motor running, watch the operation and see if you can detect the problem, like a loose pulley or slipping clutch etc.
Posted on Mar 27, 2011
Why portable dryer heats but does not spin?
Open it up and check the belt inside. A belt is around the drum and around a pulley at the motor. If it is broken or has slipped off, then it wont spin.
Jan 18, 2016 | Dryers
Washer wont spin, belt turns but drum doesn't spin
washing machines belt bender spring or bender must have come loose ,
sometime it have only a spring on the motor doing both jobs !!!
look and follow the belt around the drum and motor it may help take picture with phone on the narrow place you should find the spring or bender !!
Oct 04, 2015 | Washing Machines
Drum wont spin
Drum is cradled on small wheels and a long belt around it. Sounds like the belt is broken
Jan 06, 2014 | Tricity Bendix AW1000W Front Load Washer
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
Apr 20, 2011 | Zanussi FJS1225W Front Load Washer
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
The inside drum quit turning. is there a belt that turns this and if so how do I get to it. I had the top open but could not see anything. The drum spins if I manually spin it so I know it is not bound up...
if you cant see a belt about 1/4" wide around the drum, there will be a mark where the belt was on the drum before it broke,remove front panel and restring belt around the drum,then replace front drum piece that holds the drum in place and then string belt around idler and motor pulleys and replace front cover
Mar 23, 2011 | Maytag PYE2300AY Electric Dryer
Drum wont spin cant find belt inside machine
The belt is normally around the drum,motor, and idler arm pulley.
If you remove the front of the machine it will normally expose the drum and you will see the belt around the drum...if the belt is not around the drum then it could indicate that you have a broken belt.
Sep 27, 2009 | Kenmore Dryers
My washer wont agitate or spin
If this machine is a drum type and NOT A TOP LOADER (There was no mention of the model) then the overload has possibly caused the drive belt to either break or jump off the drum pulley.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
If the belt has slipped off or has broken, it can be replaced by fitting the (new) belt around the motor drive pulley (small end) and refitting around the drum pulley, you can do this by feeding the belt around the drum pulley, by holding the belt in place and feeding onto the pulley (IT IS EASY TO GET YOUR FINGERS NIPPED BETWEEN THE BELT AND LARGE DRUM PULLEY WHEN ATTEMPTING TO FIT BELTS BACK - SO BE VERY CAREFUL)
Best of Luck!!
Jul 04, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
