Question about Cameras
Hiii... Sir.... I have Canon powerstar SD790 This camara display is problam... I Want new display... How much cast.... aney canon srevees center in vizag....
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
One vendor has the part for USD 41.34.
http://uscamera.com/cm1-4567.htm
Posted on Mar 27, 2011
Sir my jerox machine is not working problam is syestam error e 100 please solve my problam. my machine is canon I R 2000 please help me
The error code is related to the laser. I never had to replace one yet. You're most likely dealing with a bad drum. Look to see how long the drum has been in the copier, if longer than 21,000 copies then try a new drum. If you just put one in then try another one or put the old one back in to see if the error returns. I learned this the hard way by replacing several expensive components before changing the drum again. It solved the problem. Good luck
Dec 08, 2010 | Canon imageRUNNER 2000 Copier
Canon IR 300-405 Problem - E030 this problem has been indicated of per print and per copy. so plz Sir solve this promblem
dear sir i have canon IR300-405 machin.
my problem is error 030 pls full support is my solution
Oct 25, 2010 | Office Equipment & Supplies
I recently got new computer with Windows 7 Professional. My Canon PowerShot SD790 IS will not connect to computer. I have removed all the Canon files and reinstalled the Digital Camera Solution Disk 33.0...
You are going to have to download a Windows 7 driver from Canon that will allow them to communicate.
Go to this page here (click here) and under the Drivers and Software, where it says "Choose your operating system", select Windows 7.
Oct 04, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
How do you access the internal memory on a canon power shot sd790is?
The internal memory can not be accessed, you can only access the memory card that holds the photos and this done by connecting the USB cable between the camera and PC.
Oct 01, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
What size screw do I need for the canon powershot sd790 is side strap panel? Both of them have fallen out.
The Canon SD790 has a problem where the two screws in the side of the camera work themselves loose over time, then fall out. Many times people lose the two side body pieces of the camera as well!
Both screws need to be put back in place and held in with 'Locktite' so they don't fall out again.
If you do a Google search for "Canon SD790 screws " you will see in the #1 position Darntoothysam com, where you can buy the exact OEM Canon screws for $7 including shipping.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam com
Jul 31, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
CAMERA MESSAGE SD790 IS
Well, I haven't used a Canon PowerShot SD790 IS Digital Camera before, but I want to suggest this: before you start thinking of putting your camera apart, try to clean the battery terminals and the battery contacts of the camera with clean white paper, then reinsert the pack. Please be very careful when doing this so that you do not break or bend the contacts or terminals; they are usually delicate material.
Apr 18, 2010 | Canon PowerShot SD790 IS Digital Camera
When I try to start my camara , I get a msg. on the screen that says. ERROR OBJ. RESTART CAMARA
Try removing the memory card and see if that resolves the problem.
If it doesn't, remove the battery from the camera and leave it out for at least 24 hours. Hopefully this will allow any residual charge to drain and reset the camera.
If this doesn't work, there are more serious problems with the electronics at hand.
Mar 22, 2010 | Canon PowerShot SD790 IS Digital Camera
Set the correct time, using the 24-hour clock. If you do this at 3PM, for example, set the hour to 15, not to 3.
Mar 03, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
