I'm looking for the remote control code for Sting Digital Receiver IR-200
SOURCE: IR receiver on unit not working?
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
Posted on Jan 08, 2008
  • 374 Answers
SOURCE: IR remote 103781- Looking for control code for the INSIGNA TV
If you have tried locating your tv type in the back of the manual that came with the receiver and can not locate it then chances are that the remote does not ssupport your TV. You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
Posted on Jan 28, 2009
SOURCE: Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Posted on Aug 04, 2009
SOURCE: cannot find code for digital lifestyles remote control
LG codes work with digital lifestyle.
Posted on Aug 20, 2009
SOURCE: verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Posted on Mar 28, 2010
My tv wont work with the remote i can turn on by hand but remote wont do anything it has new batterys and the red light goes on
TV brand?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
LG:
1) Test the remote:
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Oct 30, 2011 | Televison & Video
Non functioning batteries ok just stopped no liquid involved not dropped
www.remotes.com
LG:
1) Test the remote:
Aug 23, 2011 | Televison & Video
Remot control dosnt work
Please try this:
1) Test the remote:
Jul 12, 2011 | LG Televison & Video
Thought remote was broke, so bought a new one, still cannot use remote for tv & it is the remote for this model
What is the make and model number of this TV? LG TV?
www.remotes.com
LG:
1) Test the remote:
Jun 03, 2011 | Televison & Video
Cant control tv from remote
Lets find out first if it is the remote controller or the remote IR receiver in the TV problem.
New batteries?
www.remotes.com
Mar 24, 2011 | Vizio 42 in. LCD TV
Remote stopped working Got new remote and it
It can be the IR remote receiver board inside the TV. Is the new remote setup for VIZIO TV?
Old VIZIO remote is bad for sure?
Dec 03, 2010 | Vizio L32 32 in. LCD HDTV
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Hi I recently change the main board of my protron 32"pltv television and my remote control does not work anymore, do I need to change the IR remote receiver
You will need the scope to find out if the IR receiver is putting out the signal to the main board, or take a chance by replacing the IR board. Did the remote work before changing the main board?
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 12, 2010 | Protron PLTV-32 Television
Why does my TV not respond to any remote, not even the original remote control. I'm unable to turn on or off or change channels. (Proview 3200)
It can be IR receiver is not working or the CPU is getting the signal from IR board but not processing the signal properly, you can try new IR receiver board.
http://www.shopjimmy.com/led-ir-assy-200-500-hx276-from-proview-3206.htm
Mar 13, 2010 | Televison & Video
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
