My computer has no sound at all,.my speaker are ok,.what will ido?
  • 34 Answers
Go to control panel and click sound to see if the hardware is working properly. If it shows a disabled state try reinstalling the driver from the motherboard cd.
Posted on Mar 27, 2011
Chep203205 audio jack board can ido without this board and just use the subwoofer
You would have to open the cabinet to gain access to the subwoofer terminals.
Nov 10, 2013 | Altec Lansing ADA 885 Computer Speakers
Au sansui d607x
If the speaker protection is activated then this would indicate that either a dc voltage is appearing across the speakers or a short circuit on one or more speaker cables. Since you are able to get normal sound through the headphone function the former is less likely and you should check for a possible shorting speaker cable. Another possible cause for the symptoms can be dry joints on the speaker protection relays.
regards from Vintie
Oct 28, 2013 | AKG Hearo 999 AudioSphere II Amplifier
DigitalBA7500G No sound coming out of the speakers except when put in test mode from the control speaker. Sound out of computer-OK, line from computer to amp-OK, power supply-OK at 12volt AC. Any...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 12, 2011 | Boston Acoustics BA7500 Computer Speakers
I have lost my sound device what can ido
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 15, 2011 | Computers & Internet
My sound card, windows everything ok, but sometimes sound doesn't come through the speaker. it gets power and everything.......even the blue light of the controller is ok......wat shud I do???? sometimes...
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 26, 2011 | Altec Lansing MX5021 Computer Speakers
I hooked up the speakers to my computer and no sound comes out of the speakers
I don't know what is the operating system you are using with your computer.Still we can check, first we need to find out if the problem is with the speaker or with the computer.
Try these steps
  • connect those speakers with other computer check the sound, if you are getting sound there it means speakers are ok need to check computer audio setup and hardware.
  • If you are not getting any sound connecting speakers with other computer then it is speakers need to replace.
Incase speakers are ok Disconnect the speakers
  • restart the computer,check if there is windows sound if not
  • right click on the volume control icon on the left hand button corner of the screen,uncheck the mute option.still not getting any sound?
  • try to download the audio driver from the dell support site.still not getting
  • need to check the internal speaker connection,if it is fine
  • go to this website http://www.kellys-korner-xp.com/xp_tweaks.htm and click on Restore sound -windows Audio service and run the tweak,YOU NEED TO USE INTERNET EXPLORER
  • still you cannot hear the sound change the internal speaker.
Even you can check the link for your speaker set up- http://pdf.crse.com/manuals/2593588231.pdf
Oct 09, 2010 | Sony SRS-D21 Computer Speakers
I am unable to get the speakers to work at all. They will not play system sounds or anything. Troubleshooter suggested that I uninstall and reinstall the speakers. So I uninstalled and went to reinstall...
Try these steps
Sep 26, 2010 | Dell A215 Computer Speakers
Ok so my speakers are not working. the green light is on but no sound comes out and i know its pluged in right
try another speaker. if OK. the problem is on Dell A215 Computer Speakers. if other speaker don't work.
Check your soundcard. reinstall the driver. and make sure the driver is install correctly.
Aug 25, 2010 | Dell A215 Computer Speakers
I have win xp and ido not have sound
Install you motherboard driver so that you sound will functioning.
Mar 30, 2010 | EPoX EP-8K3A+ Motherboard
Bass speaker buzzing
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Mar 09, 2010 | Skull Candy Skullcrushers Headset
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
