I have toshiba sd-370ekb DVD player but the tray will not open. The player will play the disc but the tray cannot be opened - help
    Brigadier General:
  • 8,909 Answers
If you look carefully at the front of the machine, you will see a tiny hole. Get a paper clip and straighten it out then insert it into the hole, this will push against the internal mechanism and free the drawer, ( if it is not damaged).
Posted on Mar 27, 2011
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
CD is hung up in the player and does not come out with the tray
There are a few solutions:
1. hit it ok just kidding
make sure when you are trying to open it does not say "disc Lock" or some sort. You can solve this problem by hitting the device menu and typing in 2005
2. Open up the device by unscrewing the six case bolts and then the 4 dvd section screws. After this I had the problem where my dvd was stuck in the play mode so the tools would just not let go. I had to gently wiggle them apart however be very careful. I have also heard that it might be a tired arm on the side that just needs some coaxing. HOpe this helps
Mar 23, 2009 | Toshiba SD-3990 DVD Player
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Toshiba DVD Video Player Model No, SD-370EKB
Check the line carrying your video signal. See if it is damaged or not hooked up properly. It is usually the yellow wire, although it can be any number of colors.
Jul 23, 2008 | Toshiba Televison & Video
DVD CODE
try this:
http://www.avforums.com/forums/showthread.php?t=508285
Jun 13, 2008 | Toshiba SD370E DVD Player
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Disc will not play
Have your set check by a tech according to your explanation it seems that you had broken a gear on inside your set.good luck to you
Apr 05, 2007 | Toshiba SD-2805 Multi-disc DVD Player
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
