Question about Hotpoint Aquarius WMA52 Front Load Washer
Washing machine blows the fuse everytime its plugged in
    President:
  • 1,489 Answers
It has a shorted circtuit. It should be professionally serviced. Leavd it unplugged. It is dangerous to use.
Charlie
Posted on Mar 27, 2011
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
May 14, 2010 | Washing Machines
Everytime we switch on at the plug, the fuse is blowing
check wheather before switching on the cycle it's going means
1)problem in your main supply to board.
if it is blowing after switching on the cycle before starting the washing means
1)problem on the heater.
if it's blowing after washing cycle means
1)problem in the wash pump/heater.
Jan 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Maytag washing machine fuse blows everytime I start machine why?
either the units motor bearings are defective,the start windings are defective or the motor start capacitor is leaking or totally shorted on the motor case
Nov 15, 2009 | Televison & Video
My washing machine keeps blowing he fuse in the plug
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
Apr 13, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Hotpoint WD440G In wash cycle and blows all household plugs
syphon out the water by getting the end of the drain hose into a basin and putting it lower than the water level. a few shakes usually gets it flowing. you probably have a short circuit. my guess would be the heater box/element to start.
Jan 30, 2009 | Hotpoint Ariston WD440G Front Load...
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Jun 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
