I'm guessing its a pressure problem how can i sort it?
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Mar 27, 2011
05 Chrysler 300c 5.7 with codes P1416 and P2784- where do I start first? what other things sind I look out for? Any Suggestions? Please Help! Thank you....
its a diesel engine right
is it turbo-ed
very complicated engines with all the electronics
best guess....could be very wrong
suggests cylinder 6 is down on intake pressure
and Input/Turbine speed sensor might be that cause of that
thats the two issues .
.might need a Chrysler service division to sort out
P1416 .Cylinder 6 Reactivation Control Performance
P2784.....generic code only
Input/Turbine Speed Sensor "A"/"B" Correlation
Oct 14, 2016 | Chrysler Cars & Trucks
Oil pressure light comes on at stops in gear when engine is warm. Light goes off in nuetral & park
Hi Cindy:
Make, model, and year would help, also kms.
I'm guessing an older vehicle with high mileage.
You could go try a heavier weight oil, like 15 w-40, or an additive like STP.
If it's not using a lot of oil between changes, it's probably old and tired.............. Sort of like me.
Cheers
Aug 05, 2016 | Cars & Trucks
The igniter doesn't stay red hot. Why does the heater quit?
In general... I guess:
(no model, make, serial number or year provided)...
"The igniter does not stay red hot"...
That is a VERY good thing... The igniter is only designed to be hot long enough to get the heat cycle started (hot surface ignition).
Typically there are heat sensors and high temp and low temperature thermostats... design to keep your units operation within safe operating thresholds.
You have not actually shared your area of concern... but an experienced GUESS (better guesses available with a couple of clues... model, make, etc.) is going to be... your burner is failing.
A careful look in immediate the area (pilot) is going to reveal some sort of thermo-couple (safety: must be hot for MAIN valve to operate).
Most likely THAT IS YOUR FAILURE POINT.
Always get three prices before you purchasee
(do indeed get ebay and amazon (but factor in shipping)).
Good luck & happy hunting!
How to Keep Your Electronic Ignition Furnace Working Properly
Feb 11, 2016 | Heating & Cooling
Why does it take 25 minutes to preheat to around 400 degrees ?
If it's a gas range, I'd guess you have a pressure problem at the source. There should be some sort of pressure regulator at the gas tank. It might need adjusting or replacing. In other words, your oven might not be getting enough gas pressure to create a large enough flame. It should take only five or ten minutes to reach 400 degrees.
Mar 25, 2015 | Whirlpool Accubake SF362LXTS Kitchen Range
My compressor comes on for a few second, makes a slight humming sound, then goes silent; any suggestions?
Please realize I'm not a professional compressor repairman.
Your description "comes on for a few second, makes a slight humming sound, then goes silent" leaves me guessing. When you say "comes on" does that mean it "makes the pumping sound of a compressor" or it "Clicks"? Allow my musings.
On a plugged in and turned on compressor the compressor's pressure switch turns on the pump motor when the pressure falls below it's set low pressure threshold (usually ~ 90 psi). The pumps pushes air into the pressure tank until the pressure reaches its high pressure threshold (usually ~ 120 psi). If the compressor is not plugged in or turned on you can hear a click when the pressure switch turns on.
Aside: Leaks, of any sort, make the pumping more frequent or longer. Bad leaks can make it pump continuous because the high pressure threshold is never reached. The leaks can be in the switch, at line connections or in the pump (valves or piston rings) itself.
I once had a low-volume ultra-quiet compressor that made little more noise than a hum when compressing. If yours is not an ultra-quiet (clicks on, hums, and quits) than I'd have to guess that the pump might be binding instead of pumping. If it is binding then the motor would over-heats and shuts off.
Some compressors are oil cooled. If an oil cooled compressor was extremely low on oil would it bind? I suspect so.
If you suspect binding I'd find a parts list for your model to work from and disassemble the pump to investigate. (see link below)
That's my best guess on limited information. Good luck.
Campbell Hausfeld Air Compressor Parts
Jan 16, 2015 | Campbell Hausfeld Extreme Contractor...
How do I get 96 duratec ford taurus to fire
You go to You Tube Video & watch some info
on that subject
Using Google-- your can read & print all sorts
of info on diagnosing Ford Ignition Systems
Have you checked for spark,fuel pressure,a good
battery
You have to test things
There is no guessing or assuming
Sep 26, 2014 | 1996 Ford Taurus
Have 2001 s10 extreme. Oil pressure low at idle,only goes up to15 pounds of pressure at 2000 rpm. motor run great,no noises. Been like this for about 7 months
change the oil and filter-use 20w50 oil and see if that helps-you are heading for a motor rebuild if it doesn't get any better-Denny
Nov 05, 2013 | 2001 Chevrolet S-10
I have a 2000 silverado 2500 4x4 auto transmission. I noticed today a puddle under the tranny. I looked at the yranny and found a black rubber tube attached to a hanger but not connected to anything...
Hi Chris. Not very familiar with these particular transmissions, but if the tube is "dripping" fluid and not "spraying" fluid, I would have to say that this tube may be some sort of pressure relief or overflow as you had suggested. Did you have the transmission serviced or add fluid recently? If so, I'd guess that it may have been slightly overfilled. As you drive your truck and the fluid in the transmission heats up it expands and fluid pressure can/will increase. If the system pressure is too high it can do as much internal damage to your transmission as running low on fluid will. This tube may the outlet of a pressure relief device. Keep an eye on it... if it persists I'd have someone qualified take a look.
Feb 06, 2013 | Cars & Trucks
Any ideas? fuel starvation on 94 m3. problem is fuel coming from filter but not reaching injectors. whats inbetween i see pipe goes under intake but what to? cheers in advance gotta get this sorted.
the only thing that would be stopping the fuel from reaching the injectors, if.. the fuel filter is good is the fuel pressure regulator, its ran by vaccum, on the end of the fuel rail, one of the lines hook to it... that would be my guess.
Dec 04, 2010 | 1997 BMW M3
How do i sort my email addresses in alphabetic order?
I guess, you are asking for sorting in Outlook,
to sort in Alphabetic order, just right click on the message tab arrange by From address. it will sought by A-Z
Oct 12, 2010 | Computers & Internet
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
