Question about Western Digital WD800AAJB 80 GB Parallel ATA Hard Drive
When i start my pc a sound comes from my 80gb H.D like tick tick and after that then sytem show desktop,then i click my computer theres i found only 2 partitions C,D. 80GB H.D have 4 partitions E,F,G,H is not showing. plz help me what i m do.
    Master:
  • 451 Answers
That is a sign, that your hard drive is dying.
please back up the data you find important ASAP.
you can also try freezing your harddrive for a day and then installing it back in your computer to access the data on other partitions if you can view them.
otherwise you will need to send the hard drive to a professional data recovery.
Posted on Mar 27, 2011
Lenovo thinkcenter internal spiker not work in win7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps you
Mar 30, 2012 | IBM Lenovo ThinkCentre M57 - Intel Core 2...
!!0xco190036!! (icardie.dll)
If this is an error message
Click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while chkdsk is in process any input may damage your computer
or you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
Feb 18, 2012 | Acer Aspire™ T180 PC Desktop
Sound not coming
First go to 'Control Panel' by pressing the start button and click "control Panel' Second, Go to Hardware and Sound if your computer is set to category view, but if your computer is in list view just click 'Sound' you can see what mode you are on the upper right corner of the screen. Third, after you click ' Sound' another window will appear, then on the 'play Back' tab click 'configure' then click 'test'. if sounds were heard then your computer's speaker are working. (make sure your computer is not on MUTE. now click 'OK' Lastly, click 'Properties' then click the 'Levels' tab, you decide here how loud your volume would be then click ok. and you are all set up. thank you.
May 07, 2011 | Lenovo ThinkCentre M55p Desktop - Intel...
My sound is not working, it said that can not found sound device, how can I make that the system look such device.? Thank you.
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 17, 2011 | Sony VAIO VGC-RB33GY PC Desktop
E 10 COD ON REGESTE PCR T 275
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
hope this helps
Jan 05, 2011 | Casio Parts Cash Register PC Desktop
Good morning ! I have a problem How would I unmute my speakers to receive sound on my Vista home computer
goto start bar and then settings goto controll panel and left click the speaker icon, the sound properties window should open, there should be a tick box marked up mute, uncheck this box, there should be another box saying put an icon in the task bar, click on this when you have a tick show click apply and close the window, you should now have sound and a speaker icon on the right hand side of the bar at the bottem of the screen, hope this helps.
Aug 16, 2010 | Computers & Internet
My sytem is not showing desktop
ctrl + alt + delete after you load it normally and this will bring up the task manager, then go to file and select new task then type in explorer
if that fixes it you need to restore your computer to when it still worked or you can just do this in safe see if it works
there is one more way, is by editind your start up options and adding explorer to the list to open when you .... start up
and last but not least reinstall windows
Jun 19, 2010 | E-Machines eMachines Desktop PC
Sytem sound problem
just try to reinstall the drivers for the sound.post your findings
Apr 22, 2008 | HP Pavilion 513n (P9850A#ABA) PC Desktop
No sound
Yes goto your control panel, open Sytem and see Device Manager. If there is any icon with yellow color in the list, it means you have missing driver. If you have any missing driver that might be for your audio controller. If so then you have to install the driver for the device. Install the driver and enjoy.
Note: If you don't have driver then Ask Me for that with your sound card manufacturer name and model no.
Thanks
Iqbal
Mar 24, 2008 | Systemax (988970) PC Desktop
Western Digital WD800AAJB 80 GB Parallel ATA Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
