Question about Pioneer Audio Players & Recorders
My pioneer computer will not start. It starts the process of loading up but then starts all over again. The number on the back is S/NO 040784161 (if that helps!) Thanks
  • Pioneer Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 27, 2011
What do I press to access the bios to reset?
Re-start the computer and well before it starts loading windows press the F2 key continuously until the screen pops up. If it does not and the computer loads and opens windows you were too late hitting the key or you were not hitting the key frequently enough. In that event you need to start the process over again by re-starting the computer again.
Dec 22, 2015 | Computers & Internet
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
Oct 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
My player will no load. It just started "loading"
Make sure you are using a good DVD. Do not used burned DVDs. Make sure that the DVD you are using works in another player. If this is all being done and still no dice then there are a few other options:
-Has the DVD player been dropped, stored on its side, knocked around?
-Has there been a disc put into the player that had a label or something that would off center it, so once it started spinning with would wobble around?
Anything like this could have knocked the inside laser out of alignment, this would be a mechanical problem that could only be corrected by Pioneer or a technician.
Or, you can eBay is as used, purchase as-is.
Feb 28, 2011 | Pioneer DV-400V-S DVD Player
The washer quits half way thru the cycle and we have to push the stop button, wait a few seconds and push start again, it starts and then stops once again and we to repeat this process. Afterward, it...
How old is your washer? There is a problem with certain models that require an upgrade. Here is a number to call 1-800-659-7026. Give them your model number and serial number off of the machine. This problem is with the control board.
Dec 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sep 12, 2010 | Kogi L7CH Monitor
One step recovery not working windows wont load.anything i can do
Hi maybethray,
Using the One Key Recovery will help you resolve the problem, windows not loading, on your machine. There might be something that you have missed out on the process. You may consider to try using the One Key Recovery once again and follow the steps below:
Reminder: Please be advise that OKR will put back your machine to it's factory settings, will reload the operating system and all the drivers for your laptop. Create a back up copy of your important files to avoid data lost. Also, make sure that the AC Adapter is plugged in during the whole process.
Here's How:
  • Turn off your computer.
  • Press the One Key Recovery button. It's an orange button near the power. Your system will automatically turn on and it will say Windows Loading Files.
  • Wait until you are directed on Lenovo One Key Rescue System page.
  • Select One Key Recovery.
  • After that, select restore from initial backup.
  • Then you will have to hit on Start.
  • Once the process is done the system will prompt you and make sure to select Reboot.
Your operating system is now reloaded to your machine. If this process will not work the other way that you can reload the OS is through the recovery disc. For this, you need to contact Lenovo so you can request for the disc to be sent out to you. Their number is 18774536686then select option number 3.
Hope this helps.
Thank you for using Fixya.
Aug 21, 2010 | Lenovo 3000 G530 Notebook
When i shut the notebook down and tryed to load it back up it will not load it gets to windows is staring and then restarts the process
Hi there!
Your computer may have an error that is causing the computer to restart, Try this one, when you turn on the computer start pressing f8, then advance boot menu should come up, after that select, disable automatic restart then the computer will start booting to windows then it should display the error, if it still stays on the screen q/o showing anything, do the f8 process again and this time select safemode.
Hope this helps!
Jun 01, 2010 | Computers & Internet
My pioneer 100 disc cd changer (Pdf906) door gets stuck when opening and closing. I haven't used it in awhile kinda sounds like it struggles half way through of both opening and closing the front part.
my pd f100 disc pioneer is blinking and the first 25 disc compartment was sticking...i opened and found the main loading system was in the way of the 25 disc compartment...the compartment was rubbing on the loading system...i am trying to back up my loading system without breaking to re start the process and stop blinking...if anyone can help let me know...marc---- yours is probably starting to rub....also,the sping under the compartment needs crazy glue so it doesn't shift....that is another sticking factor i found on mine also.the spring wants to move underneath... open your panel and make sure not to touch any circuit boards...some of them --you have to be grounded or you'll fry it....
Mar 05, 2009 | Pioneer PD-F906 100-Disc CD Changer
HOW DO I FIND THE SERIAL NUMBER AND DECODE A PIONEER CAR RADIO MODEL DEH-M6106ZH
the serial number, reads in a sticker on your hardware, it may be on the top, bottom, sides or back.
For example, this is not your device, but just a example, computer cd drive
Oct 05, 2008 | Audio Players & Recorders
Is there a way to "reset" the memory
This is the total reset process step by step i found it on
www.avicx1forums.com and it worked fine.
REMOVE DISK
HOLD RESET AND EJECT
RELEASE RESET BUT HOLD EJECT
SCREEN WILL GO BACK IN AND OUT-THEN SAYS PLEASE PRESS THE RESET BUTTON…DON’T
THEN WITH JOY PAD PRESS …
UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK (JOYPAD BUTTON INWARDS)
PASSWORD SCREEN WILL COME ON SCREEN BREIFLY
TEST MODE SCREEN APEARS-CLICK JOYSTICK TO RIGHT ONCE
SCROLL DOWN TO NUMBER 6-PROGRAM FORCED WRITE (OK)
FIND NUMBER 1 SYSTEM PROGRAM (INSERT DISK --CNDV 40/50/60?)
PRESS 1 SYSTEM PROGRAM (OK)
SELECT 2 DVD/CD ROM (OK)
SELECT LANGUAGE… (ENGLISH)
PRESS (VIEW –POS) BUTTON
SHOULD SEE SYSTEM PROGRAM GOING UP IN %
WHEN FINISHED PRESS (BACK)
FIND NUMBER 6 PROGRAM FORCED WRITE AGAIN (OK)
NUMBER 3 APPLICATION PROGRAM (OK)
SELECT 1 UK ENGLISH...THEN PRESS (VIEW – POS) BUTTON
SHOULD SEE SYSTEM GOING UP IN %
TEST MODE PAGE 1
SELECT 6 - CLEAR BACK UP MEMORY (OK)
SHOULD SAY FINISHED THEN ASKS FOR RESET BUTTON TO BE PRESSED
PRESS RESET ON FRONT OF UNIT
START SAT NAV AGAIN
ASKES FOR LANGUAGE PRESS NO (READ TEXT)
SYSTEM STARTS
BUTTONS
OK = JOYPAD INWARD
BACK = JOYPAD TO THE LEFT…NOTE THIS WILL BRING YOU BACK TO PREVIOUS PAGE
BACK = BAND BUTTON ….NOTE THIS WILL TAKE YOU BACK TO THE MAIN MENU
May 09, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
53 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
