Question about Dell Vostro 1500 Notebook
I got a Dell Vostra 1500 laptop, recentlt the computer cannot turn on with black screen only. I checked the battery power is full and once I press the on/off button, the power on light is on, the hdd light is on and then off quickly. Pls help.
  • 139 Answers
1. Try to contact dell customer support service.
2. Here nothing is wrong with your software.
3. There is a problem in your hardware, may be your HDD or RAM or motherboard is faulty.
So your problem can be solved only by dell technical support or by taking it to a repair shop.
Posted on Mar 27, 2011
Hi My dell vostra 1500 laptop is not getting started.It is showing a black screen and cursor flashing in.Pleases suggest what could i do to get my computer back in shape.
this is most likely a startup(bcd boot)error. the only way to fix this is to run setup from your recovery partition (shift f10) when starting up the computer or use a windows 7 install disk and select repair my computer when it comes up instead of installing. let the program go through the first repair attempt to repair startup and then restart the computer without the disc in the drive. should repair the problem, but if not you can alway reinstall windows. heres a tip...stop downloading illegal movies/software because this happens when you download torrents and viruses.
Feb 01, 2011 | Dell Vostro 1500 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My Dell Vostro 1500 does not turn on right now. Basically, it freezes after the Dell logo. Only plain black screen. And it stuck there forever. Anybody help please? Thanks!
leerobin
What happens it you press F8 or F12 when you turn on the computer do you get any different screen options.
Also to clarify is the screen staying on the Dell logo or is it going to a black screen.
Another thing to check does the computer still seen like it is booting up properly.
Issken
http://www.fixya.com/users/issken
May 18, 2010 | Computers & Internet
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
I have a dell inspiration 1100 and last night I was reinstalling Windows XP and all the drivers after installing the system drivers I got a diag>: I didn't know what promt to put in here so I shut the...
Since you have power on your laptop. I have this questions you need to answer: 1. have you seen Dell logo after turning on the computer? 2. After turning on the computer heard beeps? If all no do this
1. Turn off laptop remove batt and use ac adapter
2. While laptop is off press Fn key + Power button to run test check if you see display test in progress. If no, wait for 5 minutes to listen to beep codes. Once heard beeps keep pressing hold on N key. If fails turn off laptop
3. While laptop is off, press hold D key + power button. Check if you will see colors display whole screen. If no this will need to replace LCD call Dell.
If see colors whole screen replace motherboard call dell.
Oct 01, 2009 | Dell Inspiron 1100 Notebook
Dell latitude d810 laptop won't full boot on just battery power a
Connect the AC Adaptor to the Computer and turn it ON. Then, open the Run dialog box and type "msconfig" to open Microsoft System Configuration window. On the System Configuration window, click on the Startup tab then check if the checkbox beside the "LoadPowerProfile" program is marked. If yes, then shutdown the Computer. Then, remove the Battery pack and clean the Battery compartment and the metal contacts using a pencil eraser. Furthermore, you may try resetting the BIOS to its default values after reinserting the Battery.
Restart the Computer and keep on pressing the F2 key until the "Entering Setup" text appears on the screen. Then, press the "Alt+F" key to restore the BIOS to the default configuration. Then, press ESC and Enter to Exit and save the changes.
Sep 04, 2009 | Dell Latitude D810 Notebook
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
Black out screen dell inspiron 6400
Try to turn on the system with the charger plugged in and also how old is the system.if the system less than a year then try to get the battery changed and may be the motherboard.
Sep 07, 2008 | Dell Inspiron 6400 Notebook
Dell Vostro 1500 Notebook Logo
443 people viewed this question
Alun Cox
