Question about HP Compaq nc4200 Notebook
When i put my sd card into the slot nothing comes up, i tried to download some software but it said what i was about to download was older than what i already had installed. how can i get the photo's to show up when i insert the sd card?
  • 139 Answers
1. Check in the device manager for the devices missing drivers.
2. Install them using the disk you must have got with the laptop.
3. Then check if your card is working.
4. If not your card reader must be faulty, get it checked by HP service center.
Posted on Mar 27, 2011
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
Last software download
are you trying to download your photos onto your computer if so you can take the sd card out and put it in your computer slot for sd and download them from there. or you can go onto computer and download the software for that camera.
Jan 24, 2013 | Olympus MJU 300 Digital Camera
Memory card error
The GR-DF570 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot it's electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
If you need a manual, you may download a copy here.
Sep 07, 2012 | JVC GR-DF570 DV Digital Camcorder
I put my sd card in slot to download pic and its not reading
If you have not used this card with this laptop before it is possible there is an incompatibility with the card type and the reader. SDHC cards are generally no compatible with card readers built into laptops. IT is due to the compression algorithm used to increase the storage capacity on the card. There is no PHYSICAL difference the higher storage capacity is made possible by configuring the way data is stored and revision 1.0 of card readers arent compatible. Try going to Acer and downloading a newere version of the card reader software if this doesnt work, try an older version card if possible.
Aug 02, 2010 | Acer Aspire 5920-6727 Notebook
ET1331G-03w Multicard reader problem...
I would check all the slots if that is the only slot giving you problems then that slot may be bad.
Jan 04, 2010 | E-Machines eMachines Desktop PC
Nothing happens when I put in a 2gb SD chip
Check to make sure it isn't an SDHC card. Most older card readers aren't able to read the formatting of the newer cards. You may need to buy a new card reader with SDHC support.
Jun 08, 2009 | Compaq tc4400 Tablet PC
Sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Apr 21, 2009 | Computers & Internet
SD card slot nothing happens
Sounds like it is defective I just came across 2 bad scandisk cards both 2 gig.
Jan 26, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Navigon 7100 Fatal Application Error
I had the same problem with my unit.
Did you try to reload ALL the files back to the memory card?
This as a slow process,but it seems to go a little faster if you use a card reader.
Format card using FAT option,not FAT32.
Hope this helps
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
HP Compaq nc4200 Notebook Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
