Question about Sony Computers & Internet
My Sony Vaio AR18GP stopped working. The power supply went bang and, since then, the laptop doesn't power up or display any lights at all. Nothing. Totally dead. I took the case off and found that the power is definitely getting to the motherboard. Other than testing the 19.5v supply, I cant find anything else that would stop it working. Any ideas? Motherboard blown?
MikeNJ1964
  • 398 Answers
SOURCE: Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Posted on Jun 28, 2007
  • 68 Answers
SOURCE: laptop motherboard repair components
The best way to find the part you need is search around for the board manufactures name. Then goto there web site. You may be able to download technical data right off the manufactures web site. Over heating is a big problem with lap tops. You never want to place your laptop on a soft surface when its on. A soft surface blocks the fan from extracting heat from your laptop , resulting in a over heat and eventually failure. You want to place your lap top on a hard surface when its on. This will provide ample room for your fans to cool your lap top efficiently. You can also purchase a laptop docking plate. It not only is a hard surface but also it has its own fan to increase the cooling capability of your laptop.
Posted on Sep 22, 2007
  • 3 Answers
SOURCE: Sony Vaio PCG-K86P laptop
fjhdsjafjkds
Posted on Jan 02, 2008
SOURCE: Dead laptop
where is reset button
Posted on Jan 18, 2008
scottyfixit
  • 186 Answers
SOURCE: Won't Charge
Common fix for this problem is a simple Power Management Unit (PMU) reset. This will basically re-sync the battery "brain" to the computer so they when when to charge and when to stop. To do this, simply turn your computer off, remove battery and power cord and hold the power button down for 7-15 seconds. Then you MUST wait 15 seconds after pressing the button before applying power or inserting battery. 75% chance this will fix your problem. If Not, Replace Adapter/Charger. They have a microchip in them that can go bad that senses when to send more current to charge battery. Apple motherboards are generally better built so I'm not suspecting that at this moment. Let me know what you find out.
Posted on Jun 20, 2008
Sony vaio pcg7176p laptop stopped working. the on light(green) and charge light (orange) does work but when I start it, it displays the vaio logo and then nothing. sometimes it will display a message
OK either your hard dive has crashed or stopped working altogether.
When you hit f2 look for basic settings or something like that and see if
you can see your HDD listing. Then post again.
Apr 08, 2014 | Sony Computers & Internet
Sony vaio pcg-2j3l desktop will not power on
Just to clarify, the box (power brick) in the middle of the power cord is the power supply. With that said, there is a light on the box (may be green, blue, or some other color). Does it come on when you plug it in (assuming that the wall outlet or serge protector has power)? If it doesn't then the power cable needs to be replaced. If it does then there is something wrong with either the cable going between the box and the computer, the power connector, or the connector on the computer.
Oct 19, 2012 | Computers & Internet
Sony VGN-FW41E not starting...
Power supply in the laptop may have went bad
Aug 27, 2012 | Computers & Internet
My sony vaio vgn-nw320f was totally dead.i had pulled up the battery cause it could not log off.please help me.....
Most sony laptop power supplies have a power LED that indicates if the device is A) plugged in {ok it happens!}, or B) fried and not providing power to the laptop. Check this first. If the power supply is plugged in and the LED is on (usually green or red) then see if you have ANY lights on the laptop itself. Its possible that your LCD display went bad but that the laptop is otherwise running. You may see a power, hard drive or wireless network light on if the laptop works but the LCD went bad. You can also connect an external monitor to the laptop and power it up to check the LCD.
I've also seen where the battery goes bad and it keeps the laptop from booting. Try removing the battery and power up (with the ac adapter plugged in) again.
If neither of these helps, you may be looking at some kind of internal short on the motherboard which is big money. Hopefully that isn't the case.
Hope this helps!!
Jun 20, 2011 | Sony VAIO VGN-NW320F/B Notebook
Sony PCG-7113L no display. battery and power light is on...nothing displayed on the laptop screen
The best solution is remove the power and the battery and leave for 5min then connect them and on it . It shoiuild work. PLS REPLY OR COMMENT. THANKS
May 20, 2011 | Sony VAIO PCG-7113L LAPTOP LCD SCREEN...
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
VAIO PCG-8Y2L won't boot - no display, no nothing....
I smell a Hardware fault,or your Display might be busted...I suggest you Visit a PC store and let them check it out.
Oct 30, 2009 | Sony VAIO Notebook
Computers & Internet Logo
37 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
