Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Okl - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
  • 784 Answers
OK!
Posted on Mar 27, 2011
Instaling problems
driver error .........you may restart your laptop ..... (or) start----device and printer ------ right click---- add printer -------- etc; you add your printer driver (or) download driver (for win--7) in internet.......okl
Aug 06, 2013 | Samsung SCX Office Equipment & Supplies
AC wont turn on, climate control panel, fan ect,wont turn on Fuses , okl is there a relay i should check?
there should be a acc relay or it will say compresser relay on fuse box panel or heater relay when you open it
Dec 09, 2010 | Mazda MAZDA6 Cars & Trucks
Sorry if this posts twice. I think I might have posted an ealier question in an improper area. I have a Sony Wega 32" Trinitron Model KV-32F S200 (Year 2003) Recently, I've been getting a Green...
Hello
There are two causes for this problem. One is related with green output transistor, and the other is to chroma Ic. The most common cause is with the transistor said above. You just check the video output voltage points at picture tube base board. There are three cathodes may be marked as R,Gand B. In trinitron picture tubes, these pins are pin number [8 Blue KB], pin number [9 Green KG] and pin number [10 Red KR]; and the voltages must come approximately equal to KR=154, KB=155, and KG=163, and the main video output voltage goes to these transistors will come around 225VDC. These are not accurate voltages tor refer. It may vary by 2% to set by set. All the three transistors used will be identical in number, and usually found 2SC3271N. In your TVs case, green cathode voltage may be very low from the fault stated above I thinks. When cathode voltages goes low, emission of that cathode will increases, and colour of that cathode will be predominent. You just check these voltages, and check the main video input voltage said above too. There are three resistors of 2W fitted to the the main video voltage and collector of each transistor said above; and if any one,say the resistor fitted to green output transistor collector is faulty, or open or loose sodered, the voltage at the green cathode [pin-9] will be low causing this problem. If the transistor said above gor a leak with collector to emitter will also may the cause.
Just check it. Normally this base card of Sony TVs are marked C board. If all the transisors are found okl, and still the problem perisits, the fault must be in the Chroma Ic. It may need replacement.
In practice,I found this fault to be due to bad solderings in the base card. You just check it first and go forward.
If any doubts, contact me through Fixya. OK.
Nov 10, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Need info. Honda 5518 Tractor Lost 2 wheel drive! will only drive in 4 wheel front wheels only. need to find a service manual, if theres one to be found. Thanks
I sell used Honda 5518 tractors & attachments and have over 8 years experience working on them. You may have damaged the transmission gears that engage the rear wheels and only the front wheel drive output shaft is now operating. Easy way to check is to drain the transmission oil to see if you have an grey or silver metalflake in the oil and/or if any small gear chunks come out. If so, you have done some bad damage to the gears and maybe to the internal housing. Usually not a fixable scenario. I have a used rear transmission available if that is the case.
Does your tractor have the factory Honda Ohtsu tires on it or an aftermarket brand?
Here is a link to a unit I have for sale: http://detroit.craigslist.org/okl/grd/1903593585.html
Contact me directly through there. Thanks, Mark
Sep 01, 2010 | Honda Garden
Fuji s9100 Blurred view in the viewfinder but reads okl on lcd?
Look on the left side of the viewfinder - there's a small dial which you can rotate to adjust the viewfinder. I hope that's the problem. If not, please let me know, it's just that the problem description is quite poor.
Tom
Aug 01, 2009 | Fuji FinePix S9100 Digital Camera
Fuel injectors or fuel destributor
do not attempt to take apart fuel dist bad news pull off fuel inlet line spray dist full of carb cleaner try agin let me know has car been setting hey vote for me okl
May 26, 2009 | 1990 Volkswagen Fox
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
16 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
