Question about Kenwood KDC-MP2032 CD Player
Setting the KDC-MP2032 FM radio in pair number (0-0.8). Now on non pair numbers only (0.1-0.9)
5 Suggested Answers
  • 45 Answers
SOURCE: Kenwood KDC-MP2032 radio wiring color
YELLOW goes to the battery lead
RED goes to the ignition on lead
BLACK goes to chassis ground
Posted on Apr 05, 2009
smarthome2
  • 1114 Answers
SOURCE: kdc-mp2032 how do i get it out of protect mode
Check your speaker connections, you've got a short. Check for loose tape on any connection. Fairly common problem. If your unit is Code Protected.. Try entering the code first, If you have a code, keep it handy, any time you jump start or loose power to the radio, it needs to be re entered before it will work again. Hope this helps
Posted on Jun 02, 2009
  • 12 Answers
SOURCE: We disconnected my car battery, how do I get the
Press and hold the right control knob in like a button. 'disp sel'. Release. Move control knob left or right to select clock. Tap control knob to select and exit. You will need to do this for each source (Standby, Tuner, Aux etc).
Posted on Apr 13, 2010
  • 4981 Answers
SOURCE: need radio code for kenwood KDC V6524, serial
Kenwood codes are only available from a Main Dealer or a Radio Decoding Service
Posted on Jun 13, 2010
KENWOOD KDC-215S HOW TO SET BALANCE
Step 1:
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
Hope this helps.
Cheers,
Scott
Jan 21, 2013 | Kenwood KDC-215S CD Player
How can i take the protection off the radioKenwood (KDC-MP342suburban
You might try disconnecting the memory wire and doing the reset again. If your head unit is not where u can access the wiring harness, you can disconnect the battery. This should clear any settings you have in the radio. Of course it will require resetting the clock, stations, etc...
Apr 20, 2012 | Kenwood KDC-MP2032 CD Player
Setting the clock
press and hold the menu button for a few seconds. use the am/fm button to scroll through the memory, when you get to the clock, press and hold either the seek up or seek down button for a few seconds. use the am/fm buttons to set the hour and the seek up or down to set the minutes. when you are done. press the menu button. if you want to exit the menu, press the menu button once again.
Jan 30, 2011 | Kenwood KDC-MP2032 CD Player
Kdc-mp2032 how do i get it out of protect mode
Jun 02, 2009 | Kenwood KDC-MP2032 CD Player
Apr 05, 2009 | Kenwood KDC-MP2032 CD Player
Protect mode
my stereo kenwood kdc-mp2032 is in protect mode, í lost my manual, and i don´t know how quit this mode. can yuo help me?
Jun 19, 2008 | Kenwood KDC-MP2032 CD Player
Protect feature on kenwood car cd player
there may be a small pinhole on the front panel. find it and insert a pin (with power applied) to reset your radio. if this does not work, then go to the kenwood website and search for your item and then search for an 800 phone number to call for tech support
May 25, 2007 | Kenwood KDC-MP2032 CD Player
Kenwood KDC-MP2032 CD Player Logo
71 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
