My projector lcd tv turns on and then turns itself off and the lamp light flashes it makes a whirring sound and is still on and still has power however no picture is that a sign that the bulb has blown or is does the tv have bigger problems.
    Brigadier General:
  • 8,909 Answers
It is quite likely that the lamp is defective. The whirring sound is possibly the fan doing its cool down cycle. If the lamp has failed, it is likely that you may need a ballast unit as well as a lamp.
Posted on Mar 27, 2011
Testimonial: "thanks very much for your help "
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Will not turn on, red light flashing next to the menu button
if the fans don't turn on, they may be bad and needs replacing or rewired. if the fans turn on but not the lamp, the colorwheel may be bad (listen for a high-pitched whir when you switch it on. if no whir, replace the colorwheel). if the colorwheel is ok, replace the lamp.
Mar 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
Light went out
then it may not be the lamp, but make sure you have the right one (sp-lamp-021). also check to see if the colorwheel is moving. turn the projector on and listen for a high-pitched whir. if you don't hear one, the colorwheel needs replacing. and the lamp won't light without the colorwheel spinning.
Jul 17, 2009 | InFocus ScreenPlay 4805 Multimedia...
Unit powers on but green light flashes and no projection
if you hear a high-pitched whir, the lamp or ballast may be bad. if you don't hear a whir, the colorwheel is bad. the lamp won't turn on without the colorwheel.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Unit will not power on
Company said it was defective. Sent back for exchange.
May 30, 2008 | ViewSonic PJ501 Multimedia Projector
No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Jan 02, 2008 | Hitachi CP-X260 LCD Projector
Televison & Video Logo
Top Televison & Video Experts
