Question about Fisher and Paykel Refrigerators
My freezer door operates my fridge light but my fridge door does not
  • 2,510 Answers
Check to see if the door switch has not jammed in the off position or a wire or connector has not come loose.
Posted on Mar 27, 2011
I have a Britannia nabraska side by side fridge freezer. All of a sudden the freezer compartment is not cold enough as though the door had been left open - but 24 hours later has not got colder
You may have a bad thermostat or you could just be frosted over inside. You'll need to look behind the back panel in the freezer for syntoms if unplugging to defrost doesn't work.
Mar 23, 2015 | Refrigerators
Fridge is out of gas in fridge compartment. Freezer compartment is in order
if the freezer is operating ok,then the refrige side isnt out of gas,its the damper vent door between the freezer and refrige thats not opening to let cold air into fridge from freezer,sometimes they stick shut due to ice from condensation on this door,remove grille cover on damper door and check this,if iced up defrost it with a hair dryer,then change temp selector and make sure door then moves with temp change
Mar 24, 2011 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
I have a Model IC6 bottom freezer fridge. the fridge is working but the lights on the upper fridge went out. The freezer lights work and the compressors seem to be operating. I changed the bulbs but they...
there's a light or door switch that could be bad,look around and you'll see a switch that the door hits to turn the lights on and off,i've seen people put the bulbs in cross threaded i remove the bulb thread it in and it works try removing the bulb and put it back in again,also if you unplug the machine and stick your finger into the socket there's a metal tab in there that touches the bulb if that is pushed in to far it won't touch the bulb to work bend that out a little and try it again,all there is is the bulb the socket and the switch and the switches are pretty reliable,they're located on the side or up top where the door closes in on the machine
Nov 08, 2017 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge - Westinghouse siloueete frost free 415 problem
Temperature sensing thermostat could be going bad. Also check to make sure the refrigerator light is shutting off when you close the door. There should be a switch to control the light operation when the door is opened and closed. Operate the switch by pushing it in as if the door was closed and make sure the light goes off each time.
May 18, 2008 | Refrigerators
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
75 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
