Question about Dishwashers
Just bought a new beko dishwasher and have run at programme without dishes but the water is staying in the bottom of it.What can we do
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
If this is a NEW unit and you have problems check the sink connection. If the installer (who ever) installed the unit to the garbage disposal and did not remove the plug in the side of the garbage disposal it will NOT drain no matter what you do.
If it is connected to an Air Gap take the top off of the Air Gap by pulling the outer cover straight up and off. Then unscrew the inner cap nut noting the installed position of the cap (only goes on one way!) Inspect for any pieces of rubber or debris. Remove any debris and re-install the inner U cap and nut.
Last check the drain hose for kinks. (Possibly it folded over when the unit was pushed into place.) Make sure to inspect the whole hose from the dishwasher connection to the sink connection for any signs of kinks. Straighten the hose and if it keeps folding over tape something to the outside of the hose to keep it straight. (Anything about 10 inches long, hard and straight) Tape in 2 places.
If all of the above does not resolve the issue look inside the tub under the lower wash arm for any signs of plastic that may have been left in the machine post installation that is now covering the screens / inlet vanes to the pump.
Thanks for choosing FixYa,
Kelly
Posted on Mar 27, 2011
DW1644 Beko integrated dishwasher fault. The machine doesn't clean very well, dried bits (like sand) on dishes and glassware cloudy. It's got sufficient salt, rinse aid etc. The filter is clean. I've...
I have same problem with mine (not BEKO) what I have discovered is, it seem to be where the water hasn't run off properly before drying, so I make sure I don't put anything in flat where water can collect. It's not always possible to put things in that are not flat, but try that
Dec 14, 2014 | Beko Dishwashers
Beko dw 600 dishwasher, all programme lights stay on and it wont run or clear
I had this problem and followed the advice from Gallagher to no avail.
I sorted it as follows andd bear to mind I have never seen inside a dishwasher. I found the float valve and removed the connection to open circuit the switch, still the same, I then did the same to the sensor in the water container still the same. I concluded that the only thing left was the control module in the door.
I got the pcb on line for 22-00 and fitted it. job sorted
It says the changing of the module requires an expert, dont know why its a piece of cake.
Jul 08, 2012 | Beko Dishwashers
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Jun 29, 2009 | Beko 24 in. D3421F Free-standing...
Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
