Question about Ovens
My Omega oven has stopped working: single oven, air forced. The power is on, fuses intact, the timer works, the selector knob works, but when the thermostat is set the "oven on" indicator does not work, the internal light is not able to be turned on, the elements do not heat and fans don't go. It was all working just the other day. Any suggestions on where the problem might be would be greatly appreciated!
  • 2,510 Answers
The oven has a thermal trip switch behind the back wall of the oven and is under the back cover. It is attached to the back outside wall of the oven towards the top. Some thermal switches can be reset but most usually have to be changed. If you are handy you may be able to open the switch and click the little disc backwards and reassemble the switch. Make sure to refit the disc the right way around. Ensure that the power to the oven is off or the plug is pulled out before attempting to remove the back cover.
Posted on Mar 27, 2011
Testimonial: "Prompt reply that got me looking in the right direction."
Oven not working
Gas stove check gas oven safety value
Mar 17, 2014 | Ariston Technologies Ovens
Oven is finished cleaning but the door says "locked". The panel just shows the time and "locked" in red, under it. Help
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.)
Set SELECTOR knob to OFF
Set TEMPERATURE knob to CLEAN
Press CANCEL button (on right) twice.
Slide the locking bar to the left and the oven door will open
Jan 16, 2011 | Jenn-Air JJW8530C Expressions Collection...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I HAVE A JENN AIR WALL OVEN AND WAS CLEANING AND MY JENN AIR MICROWAVE STOP WORKING DO YOU HAVE ANY IDEA'S
Check for a tripped breaker or blown fuse in your fuse box. Assuming they are separate units there is no common connection other then the power source.
Good Luck,
Gilshultz
Dec 03, 2009 | Jenn-Air JJW8530C Expressions Collection...
Removed dial knobs, put back on oven doesn't work
possibilities are that the spindle retaining clip is missing giving the impression that the oven thermostat is being turned when infact it i s slipping, or the oven is in auto mode if timer model.
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Neff B1428
If it is a digital timer and u have display, thenyou must make sure it is set to manual and not flashing auto, or the oven will not work.
If it is an anologue timer tweak the knobs until you can see a hand symbol showing this is the manual mode.
If no display of any kind, and u are sure u have a supply to oven then timer could be faulty.
Hope this helps.
U must ensure that u have a supply to the oven befor trying to alter timer.
Plz rate solution.
Thanks.
Dec 31, 2008 | Neff B1428 Nostalgic Single circotherm...
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Oven will not heat?
you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
Jun 12, 2007 | Bosch HBN 43L550B SS Electric Single Oven
Locking mechanism for jennair
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Dec 24, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
739 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
